Nc18 php-fpm cpu is too high please help me
example
longer
example
here
Nextcloud version (eg, 18.0.2): 18.0.2
Operating system and version (eg, Ubuntu 20.04):centos7.4
Apache or nginx version (eg, Apache 2.4.25): 1.14.2
PHP version (eg, 7.1):7.3
when use jmeter login to /apps/files only 15 concurrent.THE php-fpm CPU is too high.
my server is esxi virtual machine.WEB SERVER: 8cpu 32GB memory.MYSQL SERVER 8cpu 32GB memory.
This is use jmeter
This is one user WEB login.success login about 1.5s. Refresh other url is the same problem.
Is this the first time you’ve seen this error? (Y/N):yes
![image|690x293](upload://sEm36TgzNxOGCJk9t6ZWMNTJoc8.png)
  'instanceid' => 'xxxxx',
  'passwordsalt' => 'xxxx',
  'secret' => 'xxxx',
    0 => 'xxxx.cn',
  'version' => '18.0.2.2',
  'overwrite.cli.url' => 'https://xxxxx.cn',
  'dbname' => 'nextcloud',
  'dbhost' => '192.168.106.215',
  'dbport' => '3306',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'xxxx',
  'default_language' => 'zh_CN',
  'default_locale' => 'zh_CN',
  'logtimezone' => 'Asia/Shanghai',
  'tempdirectory' => '/var/big_temp_file/',
  'lost_password_link' => 'https://xxxxxx.com',
  'remember_login_cookie_lifetime' => 86400,
  'session_lifetime' => 86400,
  'session_keepalive' => true,
  'skeletondirectory' => '',
  'has_internet_connection' => false,
  'logfile' => '/data/log/nextcloud.log',
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'redis' =>
    'host' => '127.0.0.1',
    'port' => 6379,
    'timeout' => 0.0,
nginx log is all OK.
sorry.
when use jmeter login to /apps/files only 100 concurrent.THE 15 concurrent is about 60% CPU.
Perhaps 11% of cpu is not too much. Perhaps it is the number of processes on each cpu.
Is it possible to configure it? Test some settings. Please post your settings.
hey man.this is my php www.conf
pm = static
pm.max_children = 100
pm.start_servers = 16
pm.min_spare_servers = 12
pm.max_spare_servers = 36
pm.max_requests = 500
my server is 8xcpu 32GB memory…memory is OK.but CPU very high.
Ok. One process uses e.g. 10% . For 50% you can use 5 children and for 8 cpus 5 * 8 = 40 children. Perhaps you can set
pm.max_children = 50
Test the cpu with “top” again and look netcloud (jmeter) works well or not.
Can you post the number of php-fpm-processes in different tests?
i set pm.max_children = 50. CPU is 90%.same problem.
when i use my Chrome to login nc the CPU also high.
your nc is not this problem??
Did you check that Redis and APCu are online? Not seen via your screenshot. https://docs.nextcloud.com/server/18/admin_manual/configuration_server/caching_configuration.html?highlight=cache#id1
yes.this is my config.php
‘memcache.local’ => ‘\OC\Memcache\APCu’,
‘memcache.distributed’ => ‘\OC\Memcache\Redis’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
‘redis’ =>
‘host’ => ‘127.0.0.1’,
‘port’ => 6379,
‘timeout’ => 0.0,
and use php73 -m include apcu 、redis
this is my php all config
/etc/php-fpm.d/www.conf
user = www
group = www
listen = 127.0.0.1:9000
env[HOSTNAME] = $HOSTNAME
env[PATH] = /usr/local/bin:/usr/bin:/bin
env[TMP] = /tmp
env[TMPDIR] = /tmp
env[TEMP] = /tmp
mkdir -p /var/lib/php/session
chown www:www -R /var/lib/php/session/
/etc/php.ini
session.save_handler = “files”
session.save_path = “/var/lib/php/session/”
vim /etc/php-fpm.d/www.conf
php_value[session.save_handler] = “files”
php_value[session.save_path] = “/var/lib/php/session/”
/etc/php.d/opcache.ini
zend_extension=opcache.so
opcache.enable=1
opcache.enable_cli=1
opcache.memory_consumption=128
opcache.interned_strings_buffer=8
opcache.max_accelerated_files=10000
opcache.revalidate_freq=1
opcache.save_comments=1
/etc/php.d/apcu.ini
apc.enable_cli=1
/etc/php.ini
php_value upload_max_filesize 16G
php_value post_max_size 16G
php_value max_input_time 3600
php_value max_execution_time 3600
max_file_uploads = 100 #(上传文件数量)
/etc/php.ini
memory_limit = 1024M
php_admin_value[memory_limit] = 1024M
/etc/php.ini
output_buffering = 0
vim /etc/php.ini
error_log = /data/log/php_error.log
vim /etc/php-fpm.conf
error_log = /data/log/php-fpm_error.log
access.log = /data/log/php_access.log
slowlog = /data/log/php_www_slow.log
php_admin_value[error_log] = /data/log/php-fpm_www_error.log
