I tried upgrading to the latest version but now i am stuck at a screen with a greyed out Start Update button as below.
There is a template that you don’t forget any important information. Like this there is too little information to help you.
Kindly advise on the information that i need to post here so that i can get help.
said template @tflidd was referring to is called “issue template” and you’ll find it in your appshop under your admin-account of nc
Thank you for the clarification ,however how do I access admin account and I can’t login into nextcloud after I tried the update.
Geofrey Gachie.
If you post in the support forum, there is this template shown:
If you’re urgently looking for support to keep your business running, consider checking out our paid support options.
In order to help you as quickly as possible, before clicking Create Topic please provide as much of the following as you can (you can cut and paste this into your topic):
Nextcloud version (eg, 10.0.2):
Operating system and version (eg, Ubuntu 16.04):
PHP version (eg, 5.6):
Is this the first time you’ve seen this error?:
Can you reliably replicate it? (If so, please outline steps):
Remember, this information may be requested if it isn’t supplied; for fastest response please provide as much as you can Feel free to use a pastebin service, otherwise log files can be indented with 4 spaces on each line to present them in a friendlier way on the forum.
