NC11 Issues: Data Integrity and Logging Page
Hey there,
since NC11 I’m facing some little problems:
I got quite a lot of files failing the data integrity check, details see below:
[URL=http://www.file-upload.net/download-12190070/NC11Integritaetspruefung.txt.html]NC11Integritaetspruefung.txt[/URL]
Also the admin-logging page wont appear, i get stuck at the spinning loading-circle, no matter which browser i use.
edit: Actually the whole App-section as an admin is loading slow, like 20 seconds up to 2 minutes. E.g. the page non-activated Apps (also loading-circle or blank page)
Thanks in advance!
push Any idea?
Seems that copiing from the Tarball went wrong.
You should download again and start from the beginning again…
https://docs.nextcloud.com/server/11/admin_manual/maintenance/manual_upgrade.html
If after Sokos advice the problems with logging and/or app store still exist, please check your config.php according to this:
