Nextcloud version (eg, 12.0.2): 13.0.2
Operating system and version (eg, Ubuntu 17.04): Debian GNU/Linux 9.4 (stretch) (Armbian version)
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.10.3
PHP version (eg, 7.1): 7.0.27
With HSTS enabled (in Nginx) I cannot access my Nextcloud instance through the website any more.
I tried to get rid of the following warning/error:
The “Strict-Transport-Security” HTTP header is not set to at least “15552000” seconds. For enhanced security, it is recommended to enable HSTS as described in the security tips.
by following the advice on the security tips link (together with NC examples for setting up Nginx).
I uncommented in my Nginx Nextcloud config file both lines that say:
add_header Strict-Transport-Security "max-age=15768000;
reload/restart Nginx
Error I get in Chrome (in Firefox, the page just does not even start loading):
ERR_SPDY_PROTOCOL_ERROR
Didn’t see anything relevant. If there is something I should watch out for, do let me know and I’m happy to reproduce.
'instanceid' => '###REDACTED###',
'passwordsalt' => '###REDACTED###',
'secret' => '###REDACTED###,
0 => 'thatfunkyplace.wheremymonkeyis.at',
1 => 'explorethe7seas.wheremymonkeyis.at',
'datadirectory' => '/srv/nextcloud_data',
'overwrite.cli.url' => 'http://localhost',
'dbtype' => 'pgsql',
'version' => '13.0.2.1', [20/953]
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbport' => '5432',
'dbuser' => 'www-data',
'dbpassword' => ''###REDACTED###',
'logtimezone' => 'Europe/Ljubljana',
'memcache.local' => '\OC\Memcache\APCu',
# 'memcache.local' => '\OC\Memcache\Redis',
# 'redis' => array (
# 'host' => '/var/run/redis/redis.sock',
# 'port' => 0,
# 'memcache.locking' => '\OC\Memcache\Redis',
'enabledPreviewProviders' =>
0 => 'OC\Preview\Image',
1 => 'OC\Preview\MP3',
2 => 'OC\Preview\TXT',
3 => 'OC\Preview\MarkDown',
4 => 'OC\Preview\Epub',
5 => 'OC\Preview\PDF',
'theme' => '',
'loglevel' => 0,
'mail_domain' => ''###REDACTED###',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => ''###REDACTED###',
'mail_smtpauth' => 1,
'mail_smtphost' => ''###REDACTED###',
'mail_smtpport' => '465',
'mail_smtpname' => ''###REDACTED###',
'mail_smtppassword' => ''###REDACTED###',
Happy to re-produce and add the above files if needed.
