I have a functioning NC 13.0.2 installation at https://cloud.mydomain.com.
I have Lets encrypt for cloud.mydomain.com, office.mydomain.com and mydomain.com.
I add docker as described here https://www.linuxbabe.com/cloud-storage/integrate-collabora-online-server-nextcloud-ubuntu-16-04
I install collabora/code
docker run -t -d -p 127.0.0.1:9980:9980 -e ādomain=cloud\.mydomain\.comā --name collabora_nextcloud --restart always --cap-add MKNOD collabora/code
I followed the guide and run letsencrypt for the office.mydomain.com after this.
sudo letsencrypt --apache --agree-tos --email your-email-address -d office.mydomain.com
According to the guide I should now edit the new virtual host file created by Letās Encrypt ( certbot ) client. sudo nano /etc/apache2/sites-enabled/office.mydomain.com-le-ssl.conf
However that file was not created. So I created it and edited according to the instruction.
Maybe I should not have run the letsencryp as now the SSL for cloud.mydomain.com was not functioning. So I repeated my original lets-encrypt command
certbot --apache -m my@email.adress -d mydomain.com -d cloud.mydomain.com -d office.mydomain.com
After that I set up the Apache reverse proxy and configured collabora in the NC backend.
I can access both office.mydomain.com and cloud.mydomain.com - they look the same. I have the collabora icons to create files. When I create a file nothing seem to happen, but if I reload the page there is a new, empty file icon created. If I want to open a file I get Internal server error.
The first in a chain of errors in the log file say simplexml_load_string(): Entity: line 21: parser error : Specification mandate value for attribute defer at /var/www/html/nextcloud/apps/richdocuments/lib/WOPI/Parser.php#43
The docker is running and sudo docker ps gives the correct information.
I have these files in sites-enabled
/etc/apache2/sites-enabled/000-default.conf
/etc/apache2/sites-enabled/nextcloud.conf
/etc/apache2/sites-enabled/nextcloud-le-ssl.conf
/etc/apache2/sites-enabled/office.mydomain.com.conf
In /etc/apache2/sites-enabled/nextcloud.conf
<VirtualHost *:80>
DocumentRoot /var/www/html/nextcloud/
ServerName cloud.mydomain.com
Alias /nextcloud "/var/www/html/nextcloud/"
<Directory /var/www/html/nextcloud/>
Options +FollowSymlinks
AllowOverride All
Require all granted
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/html/nextcloud
SetEnv HTTP_HOME /var/www/html/nextcloud
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =mydomain.com [OR]
RewriteCond %{SERVER_NAME} =cloud.mydomain.com [OR]
RewriteCond %{SERVER_NAME} =office.mydomain.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
In /etc/apache2/sites-enabled/office.mydomain.com.conf
<VirtualHost *:80>
ServerName office.mydomain.com
RewriteEngine on
In /etc/apache2/sites-enabled/nextcloud-le-ssl.conf
DocumentRoot /var/www/html/nextcloud/ ServerName cloud.mydomain.com Alias /nextcloud "/var/www/html/nextcloud/"
AllowOverride All
Require all granted
Dav off
</IfModule>
</Directory>
ServerAlias mydomain.com
ServerAlias office.mydomain.com
Header always set Strict-Transport-Security āmax-age=15768000; preloadā
SSLCertificateFile /etc/letsencrypt/live/mydomain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mydomain.com/privkey.pem
In /etc/apache2/sites-enabled/office.mydomain.com-le-ssl.conf
ServerName office.mydomain.comInclude /etc/letsencrypt/options-ssl-apache.conf
Encoded slashes need to be allowed
AllowEncodedSlashes NoDecode
Container uses a unique non-signed certificate
SSLProxyEngine On
SSLProxyVerify None
SSLProxyCheckPeerCN Off
SSLProxyCheckPeerName Off
keep the host
ProxyPreserveHost On
static html, js, images, etc. served from loolwsd
loleaflet is the client part of LibreOffice Online
ProxyPass /loleaflet https://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://127.0.0.1:9980/loleaflet
WOPI discovery URL
ProxyPass /hosting/discovery https://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery https://127.0.0.1:9980/hosting/discovery
Main websocket
ProxyPassMatch ā/lool/(.*)/ws$ā wss://127.0.0.1:9980/lool/$1/ws nocanon
Admin Console websocket
ProxyPass /lool/adminws wss://127.0.0.1:9980/lool/adminws
Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool https://127.0.0.1:9980/lool
ProxyPassReverse /lool https://127.0.0.1:9980/lool
Maybe you can spot an apparent error.
Any help is appreciated
