NC client on M2 and MacOS 13 & 14 is not working
Hi, the desktop client 3.10 is not working on MacOS Ventura and Sonoma on Macs with M2 chips. The icon is not showing in the menu bar and there is no access to the client’s settings. The activity monitor shows that the NC client is running tholugh. Is there a fix for this? Thank you, E.
Hi, could try reinstalling the client? Apparently has seem to be the case with some apps.
In our tests, it is working fine in Sonoma on M2 chips.
