I’m running NC AIO, currently on NC 26.0.0 and I’m not able to connect to it anymore.
I use Caddy on the host and that worked really well so far and I don’t get an error message from Caddy.
AIO is on latest
and I manually updated Nextcloud with this guide.
Everything worked fine, but I lost access at some point. I can’t even say when or why. I can still access the AIO-dashboard and everything is up to date there v4.7.0
. But when I look into the logs of AIO it throws a couple of errors:
AIO-logs
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443e[0m
{"level":"info","ts":1680360352.749278,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[01-Apr-2023 14:45:52] NOTICE: fpm is running, pid 119
[01-Apr-2023 14:45:52] NOTICE: ready to handle connections
NOTICE: PHP message: Not pulling the latest database image because the container was not correctly shut down.
NOTICE: PHP message: 404 Not Found
Type: Slim\Exception\HttpNotFoundException
4
Message: Not found.
File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 76
Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(56): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(476): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/public/index.php(170): Slim\App->run()
#13 {main}
I’m not sure where the problem could be, but maybe someone finds a clue in the logs?
Nextcloud Logs
[01-Apr-2023 15:10:39] NOTICE: fpm is running, pid 270
[01-Apr-2023 15:10:39] NOTICE: ready to handle connections
[2023-04-01 15:12:49.174160 +00:00] ERROR [notify_push] src/main.rs:77: Self test failed: Error while communicating with nextcloud instance
Database Logs
2023-04-01 15:10:02.900 UTC [12] LOG: starting PostgreSQL 15.2 on aarch64-unknown-linux-musl, compiled by gcc (Alpine 12.2.1_git20220924-r4) 12.2.1 20220924, 64-bit
2023-04-01 15:10:02.901 UTC [12] LOG: listening on IPv4 address "0.0.0.0", port 5432
2023-04-01 15:10:02.901 UTC [12] LOG: listening on IPv6 address "::", port 5432
2023-04-01 15:10:02.905 UTC [12] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-04-01 15:10:02.913 UTC [22] LOG: database system was shut down at 2023-04-01 15:09:23 UTC
2023-04-01 15:10:02.921 UTC [12] LOG: database system is ready to accept connections
2023-04-01 15:15:02.993 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:15:05.964 UTC [20] LOG: checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=2.912 s, sync=0.006 s, total=2.971 s; sync files=13, longest=0.003 s, average=0.001 s; distance=139 kB, estimate=139 kB
2023-04-01 15:20:03.021 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:20:06.047 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.009 s, sync=0.007 s, total=3.026 s; sync files=12, longest=0.005 s, average=0.001 s; distance=167 kB, estimate=167 kB
2023-04-01 15:25:03.147 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:25:06.177 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.012 s, sync=0.006 s, total=3.030 s; sync files=12, longest=0.003 s, average=0.001 s; distance=151 kB, estimate=165 kB
2023-04-01 15:30:03.273 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:30:06.401 UTC [20] LOG: checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.111 s, sync=0.006 s, total=3.128 s; sync files=13, longest=0.003 s, average=0.001 s; distance=169 kB, estimate=169 kB
2023-04-01 15:35:03.476 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:35:06.504 UTC [20] LOG: checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.013 s, sync=0.006 s, total=3.029 s; sync files=12, longest=0.003 s, average=0.001 s; distance=147 kB, estimate=167 kB
2023-04-01 15:40:03.605 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:40:06.759 UTC [20] LOG: checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.126 s, sync=0.007 s, total=3.155 s; sync files=13, longest=0.003 s, average=0.001 s; distance=173 kB, estimate=173 kB
2023-04-01 15:45:03.859 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:45:06.897 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.015 s, sync=0.006 s, total=3.038 s; sync files=12, longest=0.003 s, average=0.001 s; distance=156 kB, estimate=171 kB
2023-04-01 15:50:03.993 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:50:07.130 UTC [20] LOG: checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.115 s, sync=0.006 s, total=3.137 s; sync files=13, longest=0.003 s, average=0.001 s; distance=171 kB, estimate=171 kB
2023-04-01 15:55:03.205 UTC [20] LOG: checkpoint starting: time
2023-04-01 15:55:06.505 UTC [20] LOG: checkpoint complete: wrote 33 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.268 s, sync=0.021 s, total=3.300 s; sync files=14, longest=0.017 s, average=0.002 s; distance=164 kB, estimate=171 kB
2023-04-01 16:00:03.605 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:00:06.734 UTC [20] LOG: checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.112 s, sync=0.006 s, total=3.130 s; sync files=13, longest=0.003 s, average=0.001 s; distance=182 kB, estimate=182 kB
2023-04-01 16:05:03.805 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:05:06.834 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.012 s, sync=0.006 s, total=3.029 s; sync files=12, longest=0.003 s, average=0.001 s; distance=150 kB, estimate=179 kB
2023-04-01 16:10:03.929 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:10:06.858 UTC [20] LOG: checkpoint complete: wrote 30 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=2.912 s, sync=0.005 s, total=2.929 s; sync files=11, longest=0.002 s, average=0.001 s; distance=161 kB, estimate=177 kB
2023-04-01 16:15:03.957 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:15:06.994 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.018 s, sync=0.006 s, total=3.037 s; sync files=12, longest=0.002 s, average=0.001 s; distance=144 kB, estimate=174 kB
2023-04-01 16:20:04.049 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:20:07.085 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.018 s, sync=0.006 s, total=3.036 s; sync files=12, longest=0.002 s, average=0.001 s; distance=164 kB, estimate=173 kB
2023-04-01 16:25:04.178 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:25:07.214 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.017 s, sync=0.006 s, total=3.036 s; sync files=12, longest=0.003 s, average=0.001 s; distance=149 kB, estimate=171 kB
2023-04-01 16:30:04.313 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:30:07.353 UTC [20] LOG: checkpoint complete: wrote 32 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.021 s, sync=0.006 s, total=3.040 s; sync files=12, longest=0.003 s, average=0.001 s; distance=166 kB, estimate=170 kB
2023-04-01 16:35:04.453 UTC [20] LOG: checkpoint starting: time
2023-04-01 16:35:07.494 UTC [20] LOG: checkpoint complete: wrote 31 buffers (0.2%); 0 WAL file(s) added, 0 removed, 0 recycled; write=3.018 s, sync=0.010 s, total=3.041 s; sync files=12, longest=0.006 s, average=0.001 s; distance=146 kB, estimate=168 kB
Redis Logs
Memory overcommit is disabled but necessary for safe operation
See https://github.com/nextcloud/all-in-one/discussions/1731 how to enable overcommit
1:C 01 Apr 2023 15:10:04.493 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
1:C 01 Apr 2023 15:10:04.493 # Redis version=7.0.10, bits=64, commit=00000000, modified=0, pid=1, just started
1:C 01 Apr 2023 15:10:04.493 # Configuration loaded
1:M 01 Apr 2023 15:10:04.494 * monotonic clock: POSIX clock_gettime
1:M 01 Apr 2023 15:10:04.495 * Running mode=standalone, port=6379.
1:M 01 Apr 2023 15:10:04.495 # Server initialized
1:M 01 Apr 2023 15:10:04.495 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
1:M 01 Apr 2023 15:10:04.498 * Loading RDB produced by version 7.0.10
1:M 01 Apr 2023 15:10:04.498 * RDB age 41 seconds
1:M 01 Apr 2023 15:10:04.498 * RDB memory usage when created 1.49 Mb
1:M 01 Apr 2023 15:10:04.500 * Done loading RDB, keys loaded: 1362, keys expired: 0.
1:M 01 Apr 2023 15:10:04.500 * DB loaded from disk: 0.003 seconds
1:M 01 Apr 2023 15:10:04.500 * Ready to accept connections
1:M 01 Apr 2023 15:55:42.219 * 100 changes in 300 seconds. Saving...
1:M 01 Apr 2023 15:55:42.223 * Background saving started by pid 658
658:C 01 Apr 2023 15:55:42.512 * DB saved on disk
658:C 01 Apr 2023 15:55:42.513 * Fork CoW for RDB: current 1 MB, peak 1 MB, average 0 MB
1:M 01 Apr 2023 15:55:42.525 * Background saving terminated with success
Apache Logs
Waiting for Nextcloud to start...
{"level":"info","ts":1680361846.2585971,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Sat Apr 01 15:10:46.269872 2023] [mpm_event:notice] [pid 45:tid 281473435037784] AH00489: Apache/2.4.56 (Unix) configured -- resuming normal operations
[Sat Apr 01 15:10:46.269953 2023] [core:notice] [pid 45:tid 281473435037784] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
Caddy Logs
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7804918,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x40000d7ea0"}
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7814825,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7815425,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7817957,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7819433,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2",">
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7819657,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["DOMAIN"]}
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7846658,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.784816,"msg":"serving initial configuration"}
Apr 01 15:19:50 server02 systemd[1]: Started Caddy.
Apr 01 15:19:50 server02 caddy[304401]: {"level":"info","ts":1680362390.7867298,"logger":"tls","msg":"finished cleaning storage units"}
Any help is appreciated! I already checked that the domain points to my IP address, that’s correct. I hope it’s no DB issue…
