We would like to install a new instance of collabora 18 with an S3 bucket as primary storage.
We have already tested the deployment of an instance on our bucket and it works perfectly.
But two questions arise and we have not been able to find a really clear answer:
Can we safely activate the default encryption module with a S3 storage ?
Thank you for your answers.
An important clarification that I forgot: the bucket will be an S3 Ceph bucket and not an AWS Amazon bucket.
To answer your question @Reiner_Nippes we would like to activate the Nextcloud encryption module by default and not that of Amazon.
i think you just have to set the variables in line 74 to 79 as well. in the inventory. i only tested it with aws s3 since i don’t have anything else around. feedback welcome.
just put all variables you want to change in the -e " " block. hope you get the point.
I use '$(curl ifconfig.me)' when i run this in a cloud maschine using cloud-init to provide a valid server_name for nginx and the selfsigned certificate. if you have a fqdn for your server just replace it.
