I just updated to NC 13 and tried to connect my calendars with Thunderbird 52.6/Lightning.
I followed the instructions in the manual, but could not get it to work.
The error console shows this: [calCachedCalendar] replay action failed: null, uri=https://cloud.domain.de:9443/remote.php/dav/calendars/gk/personal/, result=2147500037, operation=[xpconnect wrapped calIOperation]
This seems to be nearly the same like in this threat.
Did the old bug from 12.0.0 make it to 13.0.0??
Can someone confirm this? I will try the workaround mentioned in the threat for 12.0…
Thanks for your help!
