If you have command-line access, I would run sudo -u www-data php /path/to/nc/occ upgrade (debian/ubuntu) until it has updated everything properly. It can occur when an app was updated.
Thanks for that. I ran upgrade and everything looked ok and is said it was successful. But It still says it requires upgrading. The status command gives the following
sudo -u www-data ./occ status
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
installed: true
version: 12.0.0.29
versionstring: 12.0.0
edition:
So I’m still stuck with NC insisiting it requires upgrading.
Thanks for the quick reply. I’ve looked through some logs but don’t see anything. I may be looking through the wrong logs. Which logfile do you suggest (location/name). And anything that I should be looking for (grep any keywords). Thanks again
I ran occ upgrade and the log file indicated a fail
“level”:3,“time”:“2017-07-31T19:25:21+00:00”,“remoteAddr”:"",“user”:"–",“app”:“PHP”,“method”:"–",“url”:"–",“message”:“file_put_contents(/var/www/nextcloud/data/.htaccess): failed to open stream: Permission denied at /var/www/nextcloud/lib/private/Setup.php#515”,“userAgent”:"–",“version”:“11.0.2.7”}
I had a look at .htaccess and it showed -rw-r–r-- 1 root www-data
I executed the following script to relax permissions
#!/bin/bash
#Sets permissions of the Nextcloud instance for updating
ncpath='/var/www/nextcloud'
htuser='www-data'
htgroup='www-data'
chown -R ${htuser}:${htgroup} ${ncpath}
The log no longer shows any fails and the log displays
message":"\OC\Updater::updateEnd: Update successful",“userAgent”:"–",“version”:“12.0.0.29”}
but status shows
installed: true
version: 12.0.0.29
edition:
I’m stuck now as to where to go from here. I cannot log into NC all I get is the perform update page.
Is there anything else I can check? Thanks for the help.
Sorry for the delay in replying. I screwed up the LAMP stack with all my ‘fixes’. These are all sorted now but I’m still stuck with NC wanting to be updated even after a update is performed. What’s the best way of updating to 12.0.1RC
I recently upgraded from 12.0.3.3 to 12.0.4.3 and now I’m stuck in the upgrade mode. I followed the steps from tflidd, but Nextcloud won’t come back to normal operation:
Webpage still shows:
“Nextcloud will be updated to version 12.0.4”.
Updater.phar gives:
[root@host updater]# sudo -u nginx php updater.phar -vvv Nextcloud Updater - version: v12.0.4RC1 Current version is 12.0.4. No update available. Nothing to do.
occ upgrade says:
[root@host nextcloud]# sudo -u nginx php ./occ upgrade -vvv -n Nextcloud is already latest version
What makes me think is following log entry in the nextcloud.log:
{“reqId”:“d0ZB3Be24ZBIoq0hts8x”,“level”:1,“time”:“2018-01-21T10:13:35+00:00”,“remoteAddr”:“172.16.2.101”,“user”:"–",“app”:“updater”,“method”:“GET”,“url”:"/nextcloud/core/ajax/update.php?requesttoken=lgVgNNFJAU2jV8GBsp%2B3Sd58qfdQDLc7KNwjNpzDW7A%3D%3Azn03VpYrSgrJBLC09M7We49L45IjVOJUaYgSAeWpMN4%3D",“message”:"\OC\Updater::finishedCheckCodeIntegrity: Finished code integrity check",“userAgent”:“Mozilla/5.0 (X11; Fedora; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/63.0.3239.132 Safari/537.36”,“version”:“12.0.3.3”}
Looks like something in the deep still reminds itself to Version 12.0.3.3.
I cannot access the Admin Webpage any more, but I remember after upgrade the Version shown in the Admin Panel still showed 12.0.3.
Where does this version entry come from? This may be the root cause of the stuck in upgrade.
Thanks for any hints on that.
Roman
[UPDATE:] Forgot to mention the upgrade has been performed on december, 16th. After a system reboot some days ago the upgrade front page returned.
I fiddled with the installation and upgrade backwards/forwards, also returned to a kernel before metdown/spectre patches and so on, nothing fixed the problem. Then I found a hint in another forum, Nextcloud would not work with php version 7.2+
I then studied the dnf.rpm.log and found an upgrade entry from php-7.1.10 to php-7.1.13 and did a downgrade.
“dnf downgrade php-common”
Nextcloud returned to normal operation instantly.
So I have to hold on that version for now!
Hope this helps someone else.
Regards
Roman
[UPDATE:] For versionlock do the following:
“dnf install ‘dnf-command(versionlock)’”
“dnf versionlock php-*”
