Hello, I’ve searched for simillar topics and while I found some, I was not able to solve my issue which is:
While I maintain almost constant download speed (about 30 MB/s) , my upload speed is varying by a lot (few seconds about 12-13 MB/s then drops to 1-2 MB/s for a few seconds and that repeats as a loop). I’ve read something about chunk size and caching but I wouldn’t be able to implement anything. However, I think my problem would be somewhere else, because I am not even close enoigh to my download speed (I think up and down speed should be simillar). So what is crucial for uploading? I am listing my system parameters so you can give an advice what to improve if needed:
NC running on physical Ubuntu machine
Operating System: Linux 5.13.0-51-generic x86_64
CPU: Intel(R) Core™ i3-2100 CPU @ 3.10GHz (4 cores)
Memory: 15.34 GB
HDD - 2x Seagate Ironwolf NAS 4TB connected in RAID, so only 4TB available
In my logging I get this error which I don’t know if it is relevant to the issue I am trying to solve now:
Error scss_cacher OCP\Files\NotPermittedException:
[scss_cacher] Error: OCP\Files\NotPermittedException: at <<closure>>
0. /var/www/nextcloud/lib/private/Files/SimpleFS/SimpleFile.php line 149
OC\Files\Node\File->delete()
1. /var/www/nextcloud/lib/private/Template/SCSSCacher.php line 386
OC\Files\SimpleFS\SimpleFile->delete()
2. /var/www/nextcloud/lib/private/Template/SCSSCacher.php line 278
OC\Template\SCSSCacher->resetCache()
3. /var/www/nextcloud/lib/private/Template/SCSSCacher.php line 142
OC\Template\SCSSCacher->variablesChanged()
4. /var/www/nextcloud/lib/private/Template/CSSResourceLocator.php line 109
OC\Template\SCSSCacher->process()
5. /var/www/nextcloud/lib/private/Template/CSSResourceLocator.php line 61
OC\Template\CSSResourceLocator->cacheAndAppendScssIfExist()
6. /var/www/nextcloud/lib/private/Template/ResourceLocator.php line 78
OC\Template\CSSResourceLocator->doFind()
7. /var/www/nextcloud/lib/private/TemplateLayout.php line 342
OC\Template\ResourceLocator->find()
8. /var/www/nextcloud/lib/private/TemplateLayout.php line 250
OC\TemplateLayout::findStylesheetFiles()
9. /var/www/nextcloud/lib/private/legacy/OC_Template.php line 185
OC\TemplateLayout->__construct()
10. /var/www/nextcloud/lib/public/AppFramework/Http/TemplateResponse.php line 204
OC_Template->fetchPage()
11. /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 178
OCP\AppFramework\Http\TemplateResponse->render()
12. /var/www/nextcloud/lib/private/AppFramework/App.php line 172
13. /var/www/nextcloud/lib/private/Route/Router.php line 298
OC\AppFramework\App::main()
14. /var/www/nextcloud/lib/base.php line 1023
OC\Route\Router->match()
15. /var/www/nextcloud/index.php line 36
OC::handleRequest()
GET /index.php/apps/dashboard/
from 212.39.81.108 by flyacademy at 2022-07-14T07:32:59+00:00
*Notice!
All tests were made with a single big file (5GB for example).
All tests were made from several networks, including local (ethernet and wifi) and remote.
