My Nextcloud was running for a month, when it suddenly stopped and I get this message from the webserver:
Internal Server Error
The server encountered an internal error and …
The internal error-message is:
sudo -u www-data php /var/www/nextcloud/occ log:watch
Error core OC\HintException: Memcache \OC\Memcache\Redis not … available for local cache at
lib/private/Memcache/Factory.php line 98
0. …/Server.php line 669
OC\Memcache\Factory->__construct(
“18df … 7”,
OC\Log {},
“\OC … s”,
“\OC … s”,
“\OC … s”
1. …/Container.php line 118
OC\Server->OC{closure}("*** sensitive … *") "
My system-info:
nc-info
Gathering information…
NextCloudPi version v1.34.1
NextCloudPi image NextCloudPi_11-04-18
distribution Debian GNU/Linux 9 \n \l
automount yes
USB devices sda
datadir /media/DATA-SERVER/ncdata
data in SD no
data filesystem ext2/ext3
data disk usage 111G/470G
rootfs usage 1,9G/9,1G
swapfile /dev/mmcblk1p2
dbdir /media/Datenbanken/ncdatabase
Nextcloud check ok
Nextcloud version 19.0.8.1
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP 192.168.1.6
gateway 192.168.1.1
interface enx001e063604a3
certificates hartmut.homelinux.org
NAT loopback no
uptime 4days
The apache-server is running, it handles my website
The Redis-server is running too:
redis-benchmark -n 1000000 -t set,get -P 16 -s /var/run/redis redis.sock
====== SET ======
1000000 requests completed in 2.38 seconds
50 parallel clients
3 bytes payload
keep alive: 1
8.76% <= 1 milliseconds
====== GET ======
1000000 requests completed in 2.07 seconds
50 parallel clients
3 bytes payload
keep alive: 1
26.68% <= 1 milliseconds
100.00% <= 8 milliseconds
482625.47 requests per second
This is the redis-part of the config.php:
‘memcache.local’ => ‘\OC\Memcache\Redis’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
‘redis’ =>
‘host’ => ‘/var/run/redis/redis.sock’,
‘port’ => 0,
‘timeout’ => 0.0,
‘password’ => secret
The php-redis-module:
apt-cache policy php-redis
php-redis:
Installiert: 5.3.2+4.3.0-7+0~20210228.34+debian9~1.gbp893bd4
Installationskandidat: 5.3.2+4.3.0-7+0~20210228.34+debian9~1.gbp893bd4
Versionstabelle:
*** 5.3.2+4.3.0-7+0~20210228.34+debian9~1.gbp893bd4 500
500 https://packages.sury.org/php stretch/main armhf Packages
100 /var/lib/dpkg/status
3.1.1-1 500
500 http://httpredir.debian.org/debian stretch/main armhf Packages
My php-ini does not show this module:
php -i
phpinfo()
PHP Version => 7.3.27-9+0~20210227.82+debian9~1.gbpa4a3d6
System => Linux Wolke7 4.14.150-odroidxu4 #2 SMP PREEMPT Mon Oct 28 08:07:45 CET 2019 armv7l
Build Date => Feb 27 2021 15:51:31
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /etc/php/7.3/cli
Loaded Configuration File => /etc/php/7.3/cli/php.ini
Scan this dir for additional .ini files => /etc/php/7.3/cli/conf.d
Additional .ini files parsed => /etc/php/7.3/cli/conf.d/10-mysqlnd.ini,
/etc/php/7.3/cli/conf.d/10-opcache.ini,
/etc/php/7.3/cli/conf.d/20-posix.ini,
/etc/php/7.3/cli/conf.d/20-readline.ini,
/etc/php/7.3/cli/conf.d/20-shmop.ini,
/etc/php/7.3/cli/conf.d/20-zip.ini
My folder with available module shows it:
ls -l /etc/php/7.3/mods-available/
insgesamt 168
-rw-r–r-- 1 root root 72 Nov 3 15:33 bcmath.ini
-rw-r–r-- 1 root root 71 Nov 3 15:33 posix.ini
-rw-r–r-- 1 root root 76 Nov 3 15:33 readline.ini
-rw-r–r-- 1 root root 19 Nov 3 2018 redis.ini
-rw-r–r-- 1 root root 71 Nov 3 15:33 shmop.ini
A replay of a backup is working flawless but does nothing.
What can I do?
Spielmops
