Hopefully they’re here. Two albums, one song each. This is from Chrome on a Windows 7 machine running at 1920x1080.
As discussed; probably some caching issue and not coming up again
thank you @groovy and @anon99252149 for the big support on testing my first version and providing all this patient feedback!
5 issues were solved:
- the scanner should now handle id3 issues correctly (“not scanning local files”)
- deleted files are handled correctly
- display issues in NC & "various artists"
https://github.com/rello/audioplayer/milestone/1?closed=1
v.1.0.1 will be published soon
It would be great to have the ability to not only select by genre, but also by artist.
I fixed issues with the share and the file-actions.
the player now has a working One-Click-Play from the files app to directly play a song without indexing (alternative via Options-Menu)
When sharing a soundfile, it can be played within the share-screen
will push 1.0.2 the next days.
@groovy I need to think about how to integrate this nicely. the doing is no issue - but long lists of genres & artists would be quite ugly. i will think about it…
I agree. How about some sort of vertical navigation like this:
@Rello
thanks for this great app i haved tested it know also in NC beta 10 - works fine
looking forward for more features maybe - you have done a great job
Thank you
Please leave your + vote in the appstore to get it promoted
Features i am looking into:
- Artists (@groovy)
- timeout/timer (i need a sleep timer for the kids)
Hi Rello, I voted for your app.
Do you think it’s possible to create a stream only link?
Maybe something like dropbox is able to do. you can create a different link for stream only.
[edit]
by looking into the code of the share page, i found this link
https://www.yoursite.com/index.php/apps/audioplayer/getpublicaudiostreamfilename?token=***************
hey,
I will push the 1.0.2 today or tomorrow. then it will work. there was a bug in the code.
then you can share your mp3 from the files-app via link as any other file.
when opening the link it will offer the player within the share-screen:
https://help.nextcloud.com/uploads/default/original/1X/025793fb53ad758f8306a9647c8ca6295e16ea7f.png
Hi Rello,
The player allready works within the share-screen?
https://transfer.strengholt.nl/index.php/s/uKTfNAQdgMV5Ur3
I would like them not being able to download the file. This way they can still download it.
using thins link they don’t get a download button.
" https://transfer.strengholt.nl/index.php/apps/audioplayer/getpublicaudiostreambetterdays.mp3?token=uKTfNAQdgMV5Ur3 "
hello,
a right-click - save-as still works and is not blockable
hmm… true, but most people don’t know that
nothing is safe, the only thing you can do is try to make it hard for them.
The issue was not related to the kind of storage - it was related to the ID3-Tag determination being too picky.
It shoult work now.
Do you still have the issue with the current 1.0.1?
Here is the problem: i could hide the download button in case a playable audiofile is shared.
But what about people who want to offer a audio file for download?
I dont know how to separate this - and engancing the share-functionality itself with another checkbox or so sounds a little “expensive”
Any better idea?
Yes, in 1.0.1 Filescan in External Storage works.
Unfortunately it stops at some files and I have to restart it very often:
owncloud.log shows this:
{“reqId”:“gs9FwaAI4V+ePemjhToW”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“fopen(/var/ocdata/mucke-share/cache/audioplayer-import-1469956777): failed to open stream: No such file or directory at /var/www/nextcloud/lib/private/files/storage/local.php#261”,“level”:3,“time”:“2016-07-31T09:19:50+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“gs9FwaAI4V+ePemjhToW”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“fread() expects parameter 1 to be resource, boolean given at /var/www/nextcloud/lib/private/files/storage/wrapper/encryption.php#849”,“level”:3,“time”:“2016-07-31T09:19:50+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“gs9FwaAI4V+ePemjhToW”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“fclose() expects parameter 1 to be resource, boolean given at /var/www/nextcloud/lib/private/files/storage/wrapper/encryption.php#850”,“level”:3,“time”:“2016-07-31T09:19:50+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“DDvczmN2zXbKe+5zESZT”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“filemtime(): stat failed for /var/ocdata/mucke-share/cache/audioplayer-import-1469956777 at /var/www/nextcloud/lib/private/files/storage/local.php#159”,“level”:3,“time”:“2016-07-31T09:19:56+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“ZiywRpRSuWVoocYaa5AL”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“filesize(): stat failed for /var/ocdata/mucke-share/cache/audioplayer-import-1469956777 at /var/www/nextcloud/lib/private/files/storage/local.php#185”,“level”:3,“time”:“2016-07-31T09:20:09+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“ZiywRpRSuWVoocYaa5AL”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“fread(): Length parameter must be greater than 0 at /var/www/nextcloud/lib/private/files/storage/local.php#191”,“level”:3,“time”:“2016-07-31T09:20:09+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“ZvrxHZ0OkLRUtW/9Fa+m”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“filemtime(): stat failed for /var/ocdata/mucke-share/cache/audioplayer-import-1469956777 at /var/www/nextcloud/lib/private/files/storage/local.php#159”,“level”:3,“time”:“2016-07-31T09:20:13+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“vq6THYuqfNu3VWZp30v/”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“filemtime(): stat failed for /var/ocdata/mucke-share/cache/audioplayer-import-1469956777 at /var/www/nextcloud/lib/private/files/storage/local.php#159”,“level”:3,“time”:“2016-07-31T09:20:26+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“MZQ/YQshkd9ffOgVm56Q”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“filemtime(): stat failed for /var/ocdata/mucke-share/cache/audioplayer-import-1469956777 at /var/www/nextcloud/lib/private/files/storage/local.php#159”,“level”:3,“time”:“2016-07-31T09:20:28+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“VQ07nCbIqPxbKU1pzYVQ”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“filesize(): stat failed for /var/ocdata/mucke-share/cache/audioplayer-import-1469956777 at /var/www/nextcloud/lib/private/files/storage/local.php#185”,“level”:3,“time”:“2016-07-31T09:20:28+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“VQ07nCbIqPxbKU1pzYVQ”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“PHP”,“message”:“fread(): Length parameter must be greater than 0 at /var/www/nextcloud/lib/private/files/storage/local.php#191”,“level”:3,“time”:“2016-07-31T09:20:28+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
{“reqId”:“dil/3hXHl41jNzL30uQP”,“remoteAddr”:“79.232.xxx.xxx”,“app”:“index”,“message”:“Exception: {"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing ‘UPDATEoc_audioplayer_albums
SETyear
= ?,genre_id
= ? WHEREid
= ? ANDuser_id
= ?’ with params [\"\", \"10\", \"378\", \"mucke-share\"]:\n\nSQLSTATE[HY000]: General error: 1366 Incorrect integer value: ‘’ for column ‘year’ at row 1","Code":0,"Trace":"#0 \/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/DBALException.php(116): Doctrine\\DBAL\\Driver\\AbstractMySQLDriver->convertException(‘An exception oc…’, Object(Doctrine\\DBAL\\Driver\\PDOException))\n#1 \/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Statement.php(174): Doctrine\\DBAL\\DBALException::driverExceptionDuringQuery(Object(Doctrine\\DBAL\\Driver\\PDOMySql\\Driver), Object(Doctrine\\DBAL\\Driver\\PDOException), ‘UPDATE `oc_audi…’, Array)\n#2 \/var\/www\/nextcloud\/lib\/private\/db\/statementwrapper.php(73): Doctrine\\DBAL\\Statement->execute(Array)\n#3 \/var\/www\/nextcloud\/apps\/audioplayer\/controller\/scannercontroller.php(664): OC_DB_StatementWrapper->execute(Array)\n#4 \/var\/www\/nextcloud\/apps\/audioplayer\/controller\/scannercontroller.php(518): OCA\\audioplayer\\Controller\\ScannerController->writeAlbumToDB(‘Byrdmaniax’, ‘’, ‘10’)\n#5 [internal function]: OCA\\audioplayer\\Controller\\ScannerController->scanForAudios()\n#6 \/var\/www\/nextcloud\/lib\/private\/appframework\/http\/dispatcher.php(159): call_user_func_array(Array, Array)\n#7 \/var\/www\/nextcloud\/lib\/private\/appframework\/http\/dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\audioplayer\\Controller\\ScannerController), ‘scanForAudios’)\n#8 \/var\/www\/nextcloud\/lib\/private\/appframework\/app.php(110): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\audioplayer\\Controller\\ScannerController), ‘scanForAudios’)\n#9 \/var\/www\/nextcloud\/lib\/private\/appframework\/routing\/routeactionhandler.php(45): OC\\AppFramework\\App::main(‘ScannerControll…’, ‘scanForAudios’, Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#10 [internal function]: OC\\AppFramework\\routing\\RouteActionHandler->__invoke(Array)\n#11 \/var\/www\/nextcloud\/lib\/private\/route\/router.php(276): call_user_func(Object(OC\\AppFramework\\routing\\RouteActionHandler), Array)\n#12 \/var\/www\/nextcloud\/lib\/base.php(967): OC\\Route\\Router->match(‘\/apps\/audioplay…’)\n#13 \/var\/www\/nextcloud\/index.php(39): OC::handleRequest()\n#14 {main}","File":"\/var\/www\/nextcloud\/3rdparty\/doctrine\/dbal\/lib\/Doctrine\/DBAL\/Driver\/AbstractMySQLDriver.php","Line":115}”,“level”:3,“time”:“2016-07-31T09:20:30+00:00”,“method”:“POST”,“url”:“/apps/audioplayer/scanforaudiofiles”,“user”:“mucke-share”}
I can understand it’s too much work for too little usage. Do you think it’s possible to somehow easily create the stream link?
" Strengholt Transfer Cloud "
I allready asked for a more advanced mail template function, but that will take some time i guess
as tested with your file: will be fixed with the next version (tomorrow?). I switched to rawurlencode to handle all special characters correctly
I checked 3 options:
- add CSS classes to the download-Button and an additional textfield with the streaming-link. These classes can be used to disable/enable via a theme-css-file globally for your whole NC/OC instance.
- make user-settings for these 2 Options so the user can change for all his sharing-links wether they should provide the player, and/or the download-link, and/or the streaming link
- as before - but only with config.php parameters so for the whole instance
so the question is: globally or user dependent?
3 is the simplest;
2 nice but complex dev;
1 simple dev but not user/admin comfortable
