Good day,
Please help me to set up second domain to use with the same NC instance.
here are my carrent settings:
Domain 1 nginx settings
upstream php-handler {
server unix:/var/run/php/php7.4-fpm.sock;
server {
listen 80;
listen [::]:80;
server_name cloud.example1.net;
return 301 https://$server_name:443$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/live/cloud.example1.net/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/cloud.example1.net/privkey.pem;
ssl_dhparam /etc/nginx/ssl/dhparams.pem;
ssl_trusted_certificate /etc/letsencrypt/cloud.example1.net/ca.pem;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers 'TLS-CHACHA20-POLY1305-SHA256:TLS-AES-256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AE>
ssl_ecdh_curve secp521r1:secp384r1;
ssl_prefer_server_ciphers on;
ssl_stapling on;
ssl_stapling_verify on;
ssl_session_timeout 24h;
ssl_session_cache shared:SSL:50m;
ssl_session_tickets off;
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap)$ {
# Optional: Don't log access to other assets
access_log off;
location /.well-known/carddav {
location /.well-known/caldav {
rewrite ^/.well-known/webfinger /index.php$uri redirect;
rewrite ^/.well-known/nodeinfo /index.php$uri redirect;
Domain 2 settings
server {
server_name cloud.example2.net;
ssl_certificate /etc/letsencrypt/live/cloud.example2.net/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/cloud.example2.net/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/cloud.example2.net/ca.pem;
ssl_stapling on;
access_log off;
access_log off;
nano /etc/hosts
127.0.0.1 cloud.example1.net
127.0.0.1 cloud.example2.net
If I put the config in an extra file nginx is not restarting, if I put it in the same file of the Domain 1 that runs well it is restarting but the Domain 2 is not reachable.
Thanks!
