Hi Guys
I recently got my nextcloud server up and running on FreeNAS 11.3 and I can reach it via https from
I followed this post:
to get it up and running and do the SSL cert with Cloudflare.
I now need to add another two domains to access this nextcloud instance with
Https://cloud.mydomain2.com
and
Https://cloud.mydomain3.com
Now in the scripted install, it used caddy and I am not familiar with caddy at all.
Can I now just install certbot and let it do HTTP verification for the next two domains and add it on to nextcloud so that I can access it.
if anyone can point me or assist me in the right direction I would gladly appreciate it.
I am also looking into perhaps redoing the server and doing a reverse proxy jail to handle all the certs and domains but can’t find a nice updated post with multiple domains to follow.
I need a bit more love and care as I just started scratching the surface with the servers
Thanks
