Nextcloud version: 18.0.4 and 19RC1
Operating system: alpine (setup copied from official docker image fpm-alpine)
Apache or nginx version: nginx/1.16.1 (fpm-fcgi)
PHP version: 7.3.18
After installation the “move/copy” file dialog does not appear. nothing happens when i click the three dots and select “move or copy”. everything else seems to work.
i can move folders through drag and drop, webdav and desktop/android client.
Is this the first time you’ve seen this error?
yes
- this is my install script: https://github.com/flower1024/nextcloud/blob/master/app/post/root/nextcloud.sh
- please not that i have the same effect directly after OCC maintencance:install without the other steps in there
- there is an example compose file inside readme.md if you want to get a live example. i currently test without the read_only line though
log is empty
"apps_paths": [
"path": "\/home\/www-data\/html\/apps",
"url": "\/apps",
"writable": false
"path": "\/home\/www-data\/html\/custom_apps",
"url": "\/custom_apps",
"writable": true
"filelocking.enabled": "true",
"redis": {
"port": 0
"***REMOVED SENSITIVE VALUE***"
"dbtype": "mysql",
"version": "18.0.4.2",
"overwrite.cli.url": "http:\/\/localhost",
"dbport": "",
"mysql.utf8mb4": true,
"overwritehost": "***REMOVED SENSITIVE VALUE***",
"overwriteprotocol": "https"
The output of my log whenever i click the move/copy button:
nextcloud | 172.25.0.5 - 17/May/2020:18:13:59 +0200 "GET /index.php" 200
nginx | domain 87.173.75.88 - - [17/May/2020:18:13:59 +0200] "GET /apps/files/api/v1/showgridview HTTP/2.0" 200 18 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:76.0) Gecko/20100101 Firefox/76.0"
nextcloud | 172.25.0.5 - 17/May/2020:18:13:59 +0200 "PROPFIND /remote.php" 207
nginx | domain 87.173.75.88 - - [17/May/2020:18:13:59 +0200] "PROPFIND /remote.php/dav/files/flower/ HTTP/2.0" 207 3147 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:76.0) Gecko/20100101 Firefox/76.0"
just found that line in my nginx log. it seems unrelated to the actual click on that menu option though
nextcloud | 172.25.0.5 - 17/May/2020:18:34:58 +0200 "GET /index.php" 302
nginx | domain - - [17/May/2020:18:34:58 +0200] "GET /core/templates/filepicker.html HTTP/2.0" 302 0 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:76.0) Gecko/20100101 Firefox/76.0"
