type or paste code here
I’ve been working on developing my skill at installing Nextcloud on my TrueNAS system. Getting away from the jails and that complexity. But have also had continuing trouble getting the mount point in the jail to be empty.
Thus I figured that before I start the system, I’ll set the mount point. Was a good idea, but I screwed up and used Apache24/data instead of Nextcloud/data… geesh!
I tried moving files again… (done this before) and completely broke things.
I’ve checked the mysqli database and it was basically unused… thought I could just take the files out that I’d made, and start it up again… no so !
So without completely rebuilding the system, what is a guy have to do?
Apache24 working and PHP alive… Should I remove and restore Nextcloud to fix this ?
