I have the same problems with activity log of nextcloud. We are testing nextcloud now for using in our enterprise. For that we must log activities who are risks for our business, like sharing datas of our customers for example. That is possible in nextcloud. But we regonized that the normal user can change the parameters of logging his own acitivities. This ist unsafe. So my question is: How it is possible to prevent, that user can change their own activity log parameters.
Best regards
J. Lichtscheidel
Greetings from Germany
I’m sorry for my bad English
Original text in German if someone here understand German:
Wir testen gerade einen möglichen Nutzen von Nextcloud für unser Unternehmen. Hierzu möchten wir bestimmte Aktivitäten protokollieren und überwachen. Dies lässt sich in Nextcloud zwar machen. Jedoch haben wir festgestellt, dass die Benutzer in den eigenen Einstellungen die Protokollierung deaktivieren können. Dies ist uns zu unsicher. Daher meine Frage: Wie kann verhindert werden, dass Benutzer Änderungen vornehmen können zur Protokollierung ihrer eigenen Aktivitäten.
I don’t believe this is correct, “normal” users can’t change what is being logged, only someone who is a member of the admin group could make such changes.
It is of course possible to make configuration changes if you have access to that part of the filesystem where the configuration files are held, but that is the case with any system.
If you are concerned about the logs being modified, you will need to store them in a system where they can no longer be modified. An example of such a system is Splunk. An app exists that will visualise a lot of the information held in the Nextcloud logs. See here: https://splunkbase.splunk.com/app/3398/
normal user who are not in admin-Group and in no Groupadmins are be able to go to
settings
activity
and then they can change the checkboxes
So I think, you are not right. They can modify log settings. But this is my problem. They shouldn’t do that. It should bei not allowed.
We must solve this problem. Otherwise we can not use nextcloud.
I have just tried this. I removed the check box for " A new file or folder has been created" and for " A file or folder has been deleted", created and then deleted a folder. I then also removed the check box for “List your own actions in the stream” and again created and deleted a folder.
In all cases a log entry audit.log were create for each action (for creating a folder two log entries as Nextcloud creates both a “File created” and a “File written” log entry.
