Hallo,
ich kann leider keine Mitglieder zu einem Kreis hinzufügen bekomme folgende fehlermeldung:
[circles] Error: daita\MySmallPhpTools\Exceptions\RequestNetworkException: at <>
- /var/www/nextcloud/apps/circles/lib/Service/GlobalScaleService.php line 146
OCA\Circles\Service\GlobalScaleService->doRequest(daita\MySmallPhp … {}) - /var/www/nextcloud/apps/circles/lib/Service/GSUpstreamService.php line 145
OCA\Circles\Service\GlobalScaleService->asyncBroadcast(OCA\Circles\Model\GlobalScale\GSEvent {}) - /var/www/nextcloud/apps/circles/lib/Service/MembersService.php line 216
OCA\Circles\Service\GSUpstreamService->newEvent(OCA\Circles\Model\GlobalScale\GSEvent {}) - /var/www/nextcloud/apps/circles/lib/Service/MembersService.php line 181
OCA\Circles\Service\MembersService->addSingleMember(OCA\Circles\Model\Circle {}, “Dumoulin_Anet”, 1, “”, false) - /var/www/nextcloud/apps/circles/lib/Controller/MembersController.php line 52
OCA\Circles\Service\MembersService->addMember(“c2b31cba4874ea”, “XX”, 1, “”) - /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 218
OCA\Circles\Controller\MembersController->addMember(“c2b31cba4874ea”, “XX”, “1”, “”) - /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 127
OC\AppFramework\Http\Dispatcher->executeController(OCA\Circles\Cont … {}, “addMember”) - /var/www/nextcloud/lib/private/AppFramework/App.php line 157
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Circles\Cont … {}, “addMember”) - /var/www/nextcloud/lib/private/Route/Router.php line 302
OC\AppFramework\App::main(“OCA\Circles\C … r”, “addMember”, OC\AppFramework\ … {}, {uniqueId: "c2b3 … "}) - /var/www/nextcloud/lib/base.php line 993
OC\Route\Router->match("/apps/circles/v … r") - /var/www/nextcloud/index.php line 37
OC::handleRequest()
PUT /nextcloud/index.phples/v1/circles/c2b31cba4874ea/member
from 10.0.14.46 by XX at 2021-05-19T07:08:11+00:00
issue while useClient(): GuzzleHttp\Exception\RequestException; cURL error 60: SSL certificate problem: unable to get local issuer certificate (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for
Ich kann in egal welchen Kreis keine Mitglieder mehr hinzufügen, das hier ist ein Beispiel. Funktioniert seit dem Update auf NC21 nicht mehr.
PHP Version. 7.3.28, MYSQL Datenbank 10.0.38
Danke und Liebe Grüße
