example
longer
example
here
Nextcloud version (eg, 12.0.2): 18.0.4.2
Operating system and version (eg, Ubuntu 17.04): ubuntu 16.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.18
PHP version (eg, 7.1): php 7.4-fpm
When under Settings -> Maintenance -> Support -> Generate System Rapport
It will create a new ${date}.md file and share it. When it creates a random password without a special character it will fail to share the file.
- Keep Generating rapports till your system creates a random password without special charcters
Warning support Exception: Het wachtwoord moet minimaal één speciaal teken bevatten.
/var/www/nextcloud/lib/private/Share20/Manager.php - line 752:
OC\Share20\Manager->verifyPassword()
/var/www/nextcloud/apps/support/lib/Controller/ApiController.php - line 152:
OC\Share20\Manager->createShare()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 170:
OCA\Support\Controller\ApiController->generateSystemReport()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 99:
/var/www/nextcloud/lib/private/AppFramework/App.php - line 125:
/var/www/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
OC\AppFramework\App::main()
<<closure>>
OC\AppFramework\Routing\RouteActionHandler->__invoke()
/var/www/nextcloud/lib/private/Route/Router.php - line 299:
call_user_func()
/var/www/nextcloud/lib/base.php - line 1008:
OC\Route\Router->match()
/var/www/nextcloud/index.php - line 38:
OC::handleRequest()
"cloud.vstans.nl",
"office.vstans.nl"
"overwrite.cli.url": "https:\/\/cloud.vstans.nl",
"dbtype": "mysql",
"version": "18.0.4.2",
"dbport": "",
"redis": {
"port": 6379
"logtimezone": "Europe\/Amsterdam",
"has_internet_connection": true,
"check_for_working_webdav": true,
"loglevel": 1,
"log_rotate_size": 1485760,
"mail_smtpmode": "sendmail",
"app.mail.imaplog.enabled": "true",
"mail_smtpauthtype": "LOGIN",
"mail_smtpport": "587",
"enabledPreviewProviders": [
"OC\\Preview\\PNG",
"OC\\Preview\\JPEG",
"OC\\Preview\\GIF",
"OC\\Preview\\BMP",
"OC\\Preview\\XBitmap",
"OC\\Preview\\TXT",
"OC\\Preview\\MarkDown",
"OC\\Preview\\NFO"
"theme": "",
"trashbin_retention_obligation": "auto, 365",
"mail_smtpsecure": "tls",
"mail_smtpauth": 1,
"mysql.utf8mb4": true,
"app_install_overwrite": [
"admin_notifications",
"printer"
"updater.secret": "***REMOVED SENSITIVE VALUE***"
PASTE HERE
I don’t know how the password is generated and if I can control it.
