Migrate NC client data to a replacement PC
I’m preparing to replace an existing laptop, which is an NC client, to a new laptop. I plan to use my existing NC account on my new laptop. Is it necessary to disable the NC client on the old laptop before enabling NC client on the new laptop or can both laptops be active simultaneously to the same NC account?
unless your NC is miraculously much faster than mine, I’d suggest you disable the old nc client AND the new one, and use rsync (or whatever) to copy your data to the new machine before re-enabling the nexcloud client on it.
I did this to get my files moved from one laptop to another and it worked fine.
HTH,
-Ian
Good point. Thanks!
