Nextcloud version: 15.0.7
Operating system and version: Fedora 29
Apache or nginx version: nginx 1.16.0
PHP version: 7.3.5
I get the error: " The PHP OPcache module is not loaded. For better performance it is recommended to load it into your PHP installation."
I have installed APCu memcach using dnf install php-pecl-apcu
and have put 'memcache.local' => '\OC\Memcache\APCu',
in my config.php in the nextcloud directory.
I have also changed apc.enable_cli
to 1
in /etc/php.d/40-apcu.ini
and restarted both php-fpm and nginx.
I have tried escaping the slashes like 'memcache.local' => '\\OC\\Memcache\\APCu',
, but that does nothing either.
Is this the first time you’ve seen this error? (Y/N): Yes, it worked on my previous server.
'log_type' => 'syslog',
'datadirectory' => '/var/www/nextclouddata',
'updatechecker' => false,
'check_for_working_htaccess' => false,
'asset-pipeline.enabled' => false,
'assetdirectory' => '/var/www/nextcloud',
'apps_paths' =>
0 =>
'path' => '/var/www/nextcloud/apps',
'url' => '/apps',
'writable' => true,
1 =>
'url' => '/apps-appstore',
'writable' => true,
'instanceid' => '[CENSORED]',
'passwordsalt' => '[CENSORED]',
'secret' => '[CENSORED]',
0 => '[CENSORED]',
'overwrite.cli.url' => '[CENSORED]',
'version' => '15.0.7.0',
'dbname' => '[CENSORED]',
'dbhost' => 'localhost',
'dbuser' => '[CENSORED]',
'dbpassword' => '[CENSORED]',
'logtimezone' => 'UTC',
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'twofactor_enforced' => 'false',
'data-fingerprint' => '[CENSORED]',
Does anyone happen to know how to make sure APCu memcaching gets applied so the warning goes away?
