example
longer
example
here
Nextcloud version: 21.0.0
Operating system and version : CentOS 8
Apache or nginx version: Litespeed (Openlitespeed on CyberPanel)
PHP version: 7.4
I want to run NC on Redis and redis works well with other apps and CLI testings. However, something is wrong in config content.
Everything works well if I run NC on Memcached
'memcache.local' => '\OC\Memcache\APCu',
'memcache.distributed' => '\OC\Memcache\Memcached',
- But it not works with
'memcache.locking' => '\OC\Memcache\Redis',
'memcache.distributed' => '\OC\Memcache\Redis',
'redis' => [
'host' => 'localhost',
'port' => 6379,
'timeout' => 2.0,
'dbindex' => 0,
- So, to be honest, for me is not clear what exactly is wrong. I tried also to replace ‘localhost’
a) with exact same value of ‘trusted_domains’ (installation domain),
b) with ’ /var/run/redis/redis-server.sock’,
c) with ‘/tmp/redis.sock’
QUESTION
What is wrong here?
