Hello.
Is there any way to increment the max upload size for card attachments in deck?
Greetings-
Hello.
Greetings-
I think it is depending on your settings in php.ini and should be the same size as when you upload files to the Nextcloud files app?
Starting with Deck 1.3.0
new attachments are completely handled by the files app - so the default Nextcloud limitations are counting now.
