Max Filesize for Public Linked Upload
me again. I don’t see any limitation due public upload Link. Am I missing something or is it possible for anybody with my link to upload Files as large as I set the max upload size for registered Users?
Cheers
Dome
Without testing and searching further: Have you looked into the File Access control?
https://docs.nextcloud.com/server/11/admin_manual/configuration_files/files_access_control.html
Yes, this should work.
Add all registered users to a group if not already done.
The rule set then:
user’s group membership – IS NOT member of – <registered user's group>
file size (upload) – less than – <desired file size limit>
