Max amount of users
Hello everyone,
Out of curiosity :slight_smile:
Is there a limit regarding the max amount of users we may use in the Free version of Nextcloud?
There is no technical limit as far as I know. The amount of users is only limited by your hardware capabilities (to grant each user a sane performance).
oh Thank You !
I’m now testing it on a quite fast server , but i find the pages a bit slow ( the loading of the dashboard etc )
There are limits regarding the push notification via mobile app (500 users), and for the standard office setups (collabora and/or onlineoffice) as well (if you don’t create images yourself).
Did you go through the documentation tips already?
https://docs.nextcloud.com/server/latest/admin_manual/installation/server_tuning.html
