32.0.3
Linux LMDE 7 Gigi
Apache 2.4.65
Nginx 2.13.5
- Docker version
29.1.4
Yes
After updating docker within the LMDE Update Manager
AIO
Yes for domain resolutions
After I updated docker with the LMDE update manager four days ago, my mastercontainer showed as unhealthy upon running docker ps, and taking it down and bringing it back up again did not fix it. I saw there was yet another update for docker in the update manager so I ran it, and after that the container wouldn’t even show in my list of running containers. I went to the compose file location and ran docker compose up -d, and it gave me an error saying “No services to build”. The compose file was working perfectly fine before the updates, so I’m guessing some change within docker caused it. While I was trying to fix it, I ran docker pull while inside the directory of the compose file for the mastercontainer, and it updated the files for the aio. After that, the aio stopped running and it too shows as unhealthy when starting it again.
Something to note: All my other docker containers continue to start by themselves and run healthily. If I update any of them with docker pull, will they too start showing as unhealthy?
Update docker
mastercontainer shows as unhealthy. Update docker again
mastercontainer no longer shows under active containers. Bringing up the compose file now shows the error “No services to build”
Pull current files within mastercontainer compose file directory, aio is updated. After starting the aio again, it too starts showing as unhealthy.
