Massive code integrity problems
Steps to reproduce
  1. Rebuild the docker nextcloud image: https://github.com/Gymnae/docker-owncloud/tree/nextcloud
  2. Build a new container
  3. Start the container and access nextcloud
Expected behaviour
Vanilla nextcloud installation should not have signature issues
Actual behaviour
Mass amounts of FILE_MISSING and signature failed
Server configuration
Operating system:
Alpine Edge docker image for nextclou
on a CoreOS host
Web server:
Nginx nginx/1.10.2
PHP-FPM
Database:
MariaDB
PHP version:
5.6.27
Nextcloud version: (see Nextcloud admin page)
10.0.1
Updated from an older Nextcloud/ownCloud or fresh install:
9.x owncloud upgrade
Where did you install Nextcloud from:
Docker image
Signing status:
Signing status This super long list of failed signing has been there since moving to docker and nextcloud with alpine. I raised it with the package maintaner, he claimed this error is not happening on his side ``` core - FILE_MISSING - core/doc/admin/_images/add_storage.png - core/doc/admin/_images/admin_filehandling-1.png - core/doc/admin/_images/admin_filehandling-2.png - core/doc/admin/_images/amazons3.png [...] - core/doc/admin/_sources/configuration_files/external_storage/google.txt - core/doc/admin/_sources/configuration_files/external_storage/local.txt - core/doc/admin/_sources/configuration_files/external_storage/nextcloud.txt - core/doc/admin/_sources/configuration_files/external_storage/openstack.txt - core/doc/admin/_sources/configuration_files/external_storage/sftp.txt - core/doc/admin/_sources/configuration_files/external_storage/smb.txt - core/doc/admin/_sources/configuration_files/external_storage/webdav.txt - core/doc/admin/_sources/configuration_files/external_storage_configuration.txt - core/doc/admin/_sources/configuration_files/external_storage_configuration_gui.txt [...] - core/doc/admin/_sources/installation/system_requirements.txt - core/doc/admin/_sources/issues/code_signing.txt - core/doc/admin/_sources/issues/general_troubleshooting.txt - core/doc/admin/_sources/issues/index.txt - core/doc/admin/_sources/maintenance/backup.txt - core/doc/admin/_sources/maintenance/enable_maintenance.txt - core/doc/admin/_sources/maintenance/index.txt - core/doc/admin/_sources/maintenance/manual_upgrade.txt - core/doc/admin/_sources/maintenance/migrating.txt - core/doc/admin/_sources/maintenance/package_upgrade.txt - core/doc/admin/_sources/maintenance/restore.txt - core/doc/admin/_sources/maintenance/update.txt - core/doc/admin/_sources/maintenance/upgrade.txt - core/doc/admin/_sources/operations/considerations_on_monitoring.txt - core/doc/admin/_sources/operations/index.txt - core/doc/admin/_sources/operations/scaling_multiple_machines.txt - core/doc/admin/_sources/operations/theming.txt - core/doc/admin/_sources/release_notes.txt - core/doc/admin/_static/ajax-loader.gif - core/doc/admin/_static/basic.css - core/doc/admin/_static/bootstrap-3.1.0/css/bootstrap-theme.css - core/doc/admin/_static/bootstrap-3.1.0/css/bootstrap-theme.css.map - core/doc/admin/_static/bootstrap-3.1.0/css/bootstrap-theme.min.css - core/doc/admin/_static/bootstrap-3.1.0/css/bootstrap.css - core/doc/admin/_static/bootstrap-3.1.0/css/bootstrap.css.map - core/doc/admin/_static/bootstrap-3.1.0/css/bootstrap.min.css - core/doc/admin/_static/bootstrap-3.1.0/fonts/glyphicons-halflings-regular.eot - core/doc/admin/_static/bootstrap-3.1.0/fonts/glyphicons-halflings-regular.svg - core/doc/admin/_static/bootstrap-3.1.0/fonts/glyphicons-halflings-regular.ttf - core/doc/admin/_static/bootstrap-3.1.0/fonts/glyphicons-halflings-regular.woff - core/doc/admin/_static/bootstrap-3.1.0/js/bootstrap.js - core/doc/admin/_static/bootstrap-3.1.0/js/bootstrap.min.js - core/doc/admin/_static/bootstrap-responsive.css - core/doc/admin/_static/bootstrap-sphinx.css - core/doc/admin/_static/bootstrap-sphinx.js - core/doc/admin/_static/bootstrap.css - core/doc/admin/_static/bootstrap.js - core/doc/admin/_static/comment-bright.png - core/doc/admin/_static/comment-close.png - core/doc/admin/_static/comment.png - core/doc/admin/_static/doctools.js - core/doc/admin/_static/down-pressed.png - core/doc/admin/_static/down.png - core/doc/admin/_static/file.png - core/doc/admin/_static/fonts/OpenSans-Bold.ttf - core/doc/admin/_static/fonts/OpenSans-Bold.woff - core/doc/admin/_static/fonts/OpenSans-Italic.ttf - core/doc/admin/_static/fonts/OpenSans-Italic.woff - core/doc/admin/_static/fonts/OpenSans-Light.ttf - core/doc/admin/_static/fonts/fontawesome-webfont.eot - core/doc/admin/_static/fonts/fontawesome-webfont.svg - core/doc/admin/_static/fonts/fontawesome-webfont.ttf - core/doc/admin/_static/fonts/fontawesome-webfont.woff - core/doc/admin/_static/img/glyphicons-halflings-white.png - core/doc/admin/_static/img/glyphicons-halflings.png - core/doc/admin/_static/img/logo_owncloud.svg - core/doc/admin/_static/img/note.svg - core/doc/admin/_static/img/note_pencil.svg - core/doc/admin/_static/img/social/diaspora.png - core/doc/admin/_static/img/social/diaspora.svg - core/doc/admin/_static/img/social/diasporaround.png - core/doc/admin/_static/img/social/facebook.png - core/doc/admin/_static/img/social/facebook.svg - core/doc/admin/_static/img/social/googleplus.png - core/doc/admin/_static/img/social/googleplus.svg - core/doc/admin/_static/img/social/mail.svg - core/doc/admin/_static/img/social/ownCloud7launch.png - core/doc/admin/_static/img/social/rss.png - core/doc/admin/_static/img/social/rss.svg - core/doc/admin/_static/img/social/twitter.png - core/doc/admin/_static/img/social/twitter.svg - core/doc/admin/_static/img/social/twitterround.png - core/doc/admin/_static/img/social/youtube.svg - core/doc/admin/_static/img/todo.svg - core/doc/admin/_static/img/warning.svg - core/doc/admin/_static/jquery.js - core/doc/admin/_static/js/jquery-1.11.0.min.js - core/doc/admin/_static/js/jquery-fix.js - core/doc/admin/_static/logo-blue.pdf - core/doc/admin/_static/logo-blue.png - core/doc/admin/_static/main.min.css - core/doc/admin/_static/minus.png - core/doc/admin/_static/plus.png - core/doc/admin/_static/pygments.css - core/doc/admin/_static/searchtools.js - core/doc/admin/_static/social/diaspora.svg - core/doc/admin/_static/social/mail.png - core/doc/admin/_static/social/mail.svg - core/doc/admin/_static/style.css - core/doc/admin/_static/styles.css - core/doc/admin/_static/underscore.js - core/doc/admin/_static/up-pressed.png - core/doc/admin/_static/up.png - core/doc/admin/_static/websupport.js - core/doc/admin/configuration_database/db_conversion.html - core/doc/admin/configuration_database/index.html - core/doc/admin/configuration_database/linux_database_configuration.html - core/doc/admin/configuration_files/big_file_upload_configuration.html - core/doc/admin/configuration_files/collaborative_documents_configuration.html - core/doc/admin/configuration_files/default_files_configuration.html - core/doc/admin/configuration_files/encryption_configuration.html - core/doc/admin/configuration_files/external_storage/amazons3.html [...] - core/doc/user/_images/files_page-4.png - core/doc/user/_images/files_page-5.png - core/doc/user/_images/files_page-6.png - core/doc/user/_images/files_page-7.png - core/doc/user/_images/files_page-8.png - core/doc/user/_images/files_versioning.png - core/doc/user/_images/gallery-1.png - core/doc/user/_images/gallery-2.png - core/doc/user/_images/hidden_files.png - core/doc/user/_images/kdes.png - core/doc/user/_images/kdes1.png - core/doc/user/_images/kdes2.png - core/doc/user/_images/kdes3.png - core/doc/user/_images/kdes4.png - core/doc/user/_images/kdes5.png - core/doc/user/_images/kdes6.png - core/doc/user/_images/kdes7.png - core/doc/user/_images/kdes9.png - core/doc/user/_images/oc_connect.png - core/doc/user/_images/oc_documents.png - core/doc/user/_images/oc_documents_edit.png - core/doc/user/_images/oc_personal_settings_dropdown.png - core/doc/user/_images/osx_webdav1.png - core/doc/user/_images/osx_webdav2.png - core/doc/user/_images/personal_settings.png - core/doc/user/_images/quota1.png - core/doc/user/_images/settings_devices.png - core/doc/user/_images/settings_devices_add.png - core/doc/user/_images/settings_sessions.png - core/doc/user/_images/video_player_2.png - core/doc/user/_images/webdav_dolphin.png - core/doc/user/_images/webdav_gnome3_nautilus.png - core/doc/user/_sources/contents.txt - core/doc/user/_sources/documents.txt - core/doc/user/_sources/external_storage/external_storage.txt - core/doc/user/_sources/external_storage/index.txt - core/doc/user/_sources/files/access_webdav.txt - core/doc/user/_sources/files/access_webgui.txt - core/doc/user/_sources/files/deleted_file_management.txt - core/doc/user/_sources/files/desktop_mobile_sync.txt - core/doc/user/_sources/files/encrypting_files.txt - core/doc/user/_sources/files/federated_cloud_sharing.txt - core/doc/user/_sources/files/file_drop.txt - core/doc/user/_sources/files/gallery_app.txt - core/doc/user/_sources/files/index.txt - core/doc/user/_sources/files/large_file_upload.txt - core/doc/user/_sources/files/quota.txt - core/doc/user/_sources/files/version_control.txt - core/doc/user/_sources/index.txt - core/doc/user/_sources/pim/calendar.txt - core/doc/user/_sources/pim/contacts.txt - core/doc/user/_sources/pim/index.txt - core/doc/user/_sources/pim/sync_ios.txt - core/doc/user/_sources/pim/sync_kde.txt - core/doc/user/_sources/pim/sync_osx.txt - core/doc/user/_sources/pim/sync_thunderbird.txt - core/doc/user/_sources/pim/troubleshooting.txt - core/doc/user/_sources/session_management.txt - core/doc/user/_sources/userpreferences.txt - core/doc/user/_sources/webinterface.txt - core/doc/user/_sources/whats_new.txt - core/doc/user/contents.html - core/doc/user/documents.html - core/doc/user/external_storage/external_storage.html - core/doc/user/external_storage/index.html - core/doc/user/files/access_webdav.html - core/doc/user/files/access_webgui.html - core/doc/user/files/deleted_file_management.html - core/doc/user/files/desktop_mobile_sync.html - core/doc/user/files/encrypting_files.html - core/doc/user/files/federated_cloud_sharing.html - core/doc/user/files/file_drop.html - core/doc/user/files/gallery_app.html - core/doc/user/files/index.html - core/doc/user/files/large_file_upload.html - core/doc/user/files/quota.html - core/doc/user/files/version_control.html - core/doc/user/genindex.html - core/doc/user/index.html - core/doc/user/objects.inv - core/doc/user/pim/calendar.html - core/doc/user/pim/contacts.html - core/doc/user/pim/index.html - core/doc/user/pim/sync_ios.html - core/doc/user/pim/sync_kde.html - core/doc/user/pim/sync_osx.html - core/doc/user/pim/sync_thunderbird.html - core/doc/user/pim/troubleshooting.html - core/doc/user/search.html - core/doc/user/searchindex.js - core/doc/user/session_management.html - core/doc/user/userpreferences.html - core/doc/user/webinterface.html - core/doc/user/whats_new.html - INVALID_HASH - lib/private/Config.php
Raw output
Array
[core] => Array
[FILE_MISSING] => Array
[core/doc/admin/_images/add_storage.png] => Array
[expected] => bbcb888ae6e48ba27f20092ae3f4afee8308ded448bec6c36a4f64c8842beae29794a09090ec6867a175555bdedc6a6fbb5799d38cc5bbe9d08b8283ff6ff799
[current] =>
                [core/doc/admin/_images/admin_filehandling-1.png] => Array
                        [expected] => 4cb6cc5aa813f2770d416997620d51d5535ebd933680e079875f34ceef89b494f621df7f17930b51b81b78b24738c1f12a681538f123d167e33fc36e1f7dde41
                        [current] =>
                [core/doc/admin/_images/admin_filehandling-2.png] => Array
                        [expected] => b3a80fe53681f2c006fb7268f0e72ce2fa4a5f101d1df885f5a5cdc486400183245894f4188c9b23bfb336217ccde2ee66629716d968364b09bda8342386195a
                        [current] =>
                [core/doc/admin/_images/amazons3.png] => Array
                        [expected] => 133d289e9d45995d44d37676f83103af1d31976c908f8778134a1d73229fde90cabf062ff84ec7a9eeed25107cf409da477c2b71d4178914e3e7fb288daaf6bc
                        [current] =>
                [core/doc/admin/_images/antivirus-app.png] => Array
                        [expected] => 3fa87684df188a11198b098b97eb80b69bb4954efa919fe92860beda6e37d6017a8c384a0bbb7bb9a422b3ca1c59b4fed4fb1ccd8cbb45f895ccdfc99384ee94
                        [current] =>
                [core/doc/admin/_images/antivirus-config.png] => Array
                        [expected] => 1d44e9eec3582326381f2f7ba4827616f30534127fb27e3a17d48e821567e3775a56be6855a3ab3223d0812a850ca35af940625378339ebaabf213dc53b045c1
                        [current] =>
                [core/doc/admin/_images/antivirus-daemon-socket.png] => Array
                        [expected] => 8c48dd0d1056db8c74b31278e7be99b01f102d9dac66c0f7c5be7c17e2b7f9c4dffc94861b7984cd85b66096b41bdaa3a0c3a9d8c62be110c82b92668c2efe7a
                        [current] =>
                [core/doc/admin/_images/antivirus-daemon.png] => Array
                        [expected] => 2b0c64590c9a1c58c3e19cfc4a0c0c411890b3c9fca6291411d3640e60b76c1403a84f15cffb337add677afbe9d85a15a26dfeb9e507f2e218d0c9d797c14684
                        [current] =>
                [core/doc/admin/_static/img/social/diasporaround.png] => Array
                        [expected] => 15908517643bc45dc83bdf3e38d4c2b5f55c45d1ac8c6a1c75de8ecf9e14616dc8fbfd1a5b24dc9c60208fbeba2358066919051f0fd3c8d23d7570c37afde9fa
                        [current] =>
                [core/doc/admin/_static/img/social/facebook.png] => Array
                        [expected] => 826d3640b4da22e1d063b1621783df7a623d0b9486c79b82a81af1c3cfd4966fc432c91cc15d079791033778d766be509d4b8d814d58c22fb78db2ef435962ee
                        [current] =>
                [core/doc/admin/_static/img/social/facebook.svg] => Array
                        [expected] => 1b670b8d34e3393364509f04072a21276c7ef3149d879f0689ddd0c110f1d2364e553d407d73bbb7b650b142969c5d5537da1bd025cc04cf7942cbcde7bbf638
                        [current] =>
                [core/doc/admin/_static/js/jquery-1.11.0.min.js] => Array
                        [expected] => 87d90a665c15d71ac872bd8bc003d9863964c7ec7ada6370b902b93c0bbd7770fe25730d946c7c6a465baa95efa74bc0e78af3f83aea615af35060cc8702a6c1
                        [current] =>
                [core/doc/admin/_static/js/jquery-fix.js] => Array
                        [expected] => 18e9d0a5e20973daa4cd3005aad38778f92ced952414d0dba727ec1ae5937a9a17dd1f54e9efe79971c4173e693cbb1337fedc6ce4c41a6aee107d8ffee0a60d
                        [current] =>
                [core/doc/admin/_static/logo-blue.pdf] => Array
                        [expected] => 76ce8b93178156512aadb4f12e139c55076cebf33ee2c22dc9f1a98ff3189c8ccc5580f80a6cd2e5c5c4914acdbb7f2b96c8a29c8847e4f16beac33fb5e3d4e3
                        [current] =>
                [core/doc/admin/_static/logo-blue.png] => Array
                        [expected] => eac6d6986ec3c959220596c2eefe30cab1eb0d7329b6c093c9e2df56c25ca3877c0374b96237a02d017187f62b7b272131c96b590b39232822b528a7e2191b0d
                        [current] =>
                [core/doc/admin/_static/main.min.css] => Array
                        [expected] => f816b4bf41c889d209a98e65e0cc7983c1ac5d0c16a1c0c75cda81cc7fff6ec79f299c549e716ba9b05ea31b0eb63abaa000fd79903c9a7103a69c8519ed46bc
                        [current] =>
                [core/doc/admin/_static/minus.png] => Array
                        [expected] => b0df36ed5ebd327b8ef468fcd9588f4fa137a613f32246b81a9f7466ef644689e8d7ff9c15053571d2b61583db95d5cc67260f1cf7e916fa08f7ac15527573ca
                        [current] =>
                [core/doc/admin/_static/underscore.js] => Array
                        [expected] => e81915a27743e049f587e2635625c882e50c910b34af2370d24a178653746d9925d91a7b4fa0e33d55de871de6e0f9a97452b7782b48881771f7f1ca34b43746
                        [current] =>
                [core/doc/admin/_static/up-pressed.png] => Array
                        [expected] => 9e4ecc5a7add27f09b95051fdef254724105312660fedc8cfaabff39ce717bc02a799ae3878cb02e9ea9b281d26fd68dedea30d0e3cbeec54ab36aee8fb4cb21
                        [current] =>
                [core/doc/admin/_static/up.png] => Array
                        [expected] => 32b0de5bf42176bf2a6b8412424450f8962c065c0d2f8842a5c8841a5306e258988c403c793601e9f2c73c372c1ea97a4a230183858b36fc2f275f25b4915761
                        [current] =>
                [core/doc/admin/_static/websupport.js] => Array
                        [expected] => ca2da3760881bdf13f565dbb721661428272e116e4f908d301412806188084c0961444a6bdd40fbd57ace26c6ced5cd4607ba286ad8834464098faaff4070246
                        [current] =>
                [core/doc/admin/configuration_database/db_conversion.html] => Array
                        [expected] => 6386be8d89d813f186b8c0761ee8a422a292238d78a050b02fe5e52470da381211e4de4cb2cf3ccac03798b2758e61e21b15e51ba381730972a2698a2eca3061
                        [current] =>
[core/doc/admin/configuration_user/user_provisioning_api.html] => Array
[expected] => 183709a94e2e5c9b83353d659dffa493fb74b5c6ff75cacf139edca417443d1143cb4aa27564e5abc837252e732527eea0da5a65dc23eaefe27dcdcce67ac4d0
[current] =>
                [core/doc/admin/contents.html] => Array
                        [expected] => f07bbcf013347924c2033f5ad977c532c20db44211e86e3b6cddeab0ab41b72fc9546552196d695a461c8c7de70d113af2fa7ff45101ee5dad3b494e016ac4fc
                        [current] =>
                [core/doc/admin/genindex.html] => Array
                        [expected] => 20974627791887a5deb12fa8ab20e0001e4965c9e8af468756f0d6d198e50be1d9f245438eea530f1591cd5edbf0df6affdb8faf37269227876a12d9855694a3
                        [current] =>
                [core/doc/admin/index.html] => Array
                        [expected] => ea361f23d0597b4be365801a563072898417f345c611d417b0d62bc6091acda7509e04f92838296370d3d2614814a0a4ecbbe41954c781fff6a04abc1601d6f4
                        [current] =>
                [core/doc/admin/installation/apps_management_installation.html] => Array
                        [expected] => 45a48a016ee2e293323c6c3303cfcf85026a202afaa4b38c3edd38b65a055a8ca3a099346ed5a7aa57ec2ccc40d78307964cda993273fae3a236ed953e5a9730
                        [current] =>
                [core/doc/admin/installation/apps_supported.html] => Array
                        [expected] => def0af23ec52aaabc452354e33f8ad134de121a157088d735c1f496de4e125293e464ad0cb1ffd2a5359880f0cb793e7cab8fb325d91801deb9788b8cf99dee0
                        [current] =>
                [core/doc/admin/installation/command_line_installation.html] => Array
                        [expected] => 4d43380024cd5dd8c5a632c9de9599d678eb65d7a86076d1bf5c67fb0d036e4c5a9787c828caeb11f53732df8c75b46ab774b221b642c3223edc6ded24f35cbc
                        [current] =>
                [core/doc/admin/installation/deployment_recommendations.html] => Array
                        [expected] => aedb4899f22aab5c592c762844bba96b378d202957df38bd51afa4bd3175ae537e8e229941af6c5c7c8749236fa90da7f53269ba9ea8f1b24dda03cc151adcd0
                        [current] =>
                [core/doc/admin/installation/index.html] => Array
                        [expected] => b7f39c05042a948791313fb987eafd2b49a25503083c3003ec6c56d9e7a46d9f76c67b0628255622a4b744487bca6e6ef2334e76846961fca7b68dd0aa86db4e
                        [current] =>
                [core/doc/admin/installation/installation_wizard.html] => Array
                        [expected] => 134034ce715d988f1452ee77e05d521229ecb1701ce9d333698aaf1f4b09d2184121402a7b7b8c6168a75b70bfccb4ba9a036f47a444f210499b301ec0a7cf24
                        [current] =>
                [core/doc/admin/installation/nginx_examples.html] => Array
                        [expected] => ee9863f23b28c2acdc6fe6f4590459f03d473015b7c1fcdac762cdeaaf99f0d6b687ca56909b1fcfaceeec15bf7c3088a17f3e8c289d554bddf1d3f014e1d301
                        [current] =>
                [core/doc/admin/installation/nginx_nextcloud_9x.html] => Array
                        [expected] => 80026a7f3fc4252b3a2a14b64de31d8daf0f4ebc41a67f7ca949813f251d86c67c22d45235bb1a2218248c9aff446601836b701afb10d2f9a7d22ec315fbf12e
                        [current] =>
                [core/doc/admin/installation/php_54_installation.html] => Array
                        [expected] => 432d11d035fbaa5d2077beb19765f1ef32d245e618ab9b4bbc7697dc5d1c6a64dfd1672da0383943fe32a8293f3ead74cf4a1bd66c760d02949fa7cefb9108a4
                        [current] =>
                [core/doc/admin/installation/php_55_installation.html] => Array
                        [expected] => 24b50caa936c80d39263ef1f7a54badbb8245b4f773111cfd2e9d2483a9c18ae8c13b29468fe08e1703ffaf81b6821d83c9b3ca04d17cafad0455ac816ab2ee3
                        [current] =>
                [core/doc/admin/installation/selinux_configuration.html] => Array
                        [expected] => a34a0e00110db53e8c49b60d560c792429c7a0f0bf3a0fb7c208862eb36987c30cf606383740bfaaa0b70dcf88a6ba7d040ee727a1e8dd272da25139b95403d0
                        [current] =>
                [core/doc/admin/installation/source_installation.html] => Array
                        [expected] => 7c03b58779bd807fb01c9bcdb9ab78d2622f1cb6c88b1d74840ea02be3144bd477d7ba46c00918e5bcb563f9a6f9777f1ccaffdf4e9a0ea541c6d95ebc4e830c
                        [current] =>
                [core/doc/admin/installation/system_requirements.html] => Array
                        [expected] => 736fbafc1ca88b3ac61fdfc6bb1480fac63e8e8d1ce06ae68f6f4ceec05aad9eb6c7dcbef82577fc22367d20fe7ce4d66a54b6ceec699b46db6887bef4a8d0fc
                        [current] =>
                [core/doc/admin/issues/code_signing.html] => Array
                        [expected] => 93aabb86705820c5f467bf23b9dbecaa7681ef97ffe892c17bb0e55d3091a04c772e2f686770fd0ce8ba2744f90e6eb29e1e3310fcecdb403ea468bf49374810
                        [current] =>
                [core/doc/admin/issues/general_troubleshooting.html] => Array
                        [expected] => 76b8ff6284715c2f04a9830e3733e608accb3fefc23b11d3489295a20da1fdffc6bbde0ab97a8752b393507000ded8b95b8d6438f442a8df5708db4fbb86ff85
                        [current] =>
                [core/doc/admin/issues/index.html] => Array
                        [expected] => 5774cd92040ef1efe29318c27a93e29bc7ee6717ee628355699f3e1ab0c0a4cfc00ce25d2f60e4712929bc2f255a97e51bd18ba39916467d639a4241e3cb10b4
                        [current] =>
                [core/doc/admin/maintenance/backup.html] => Array
                        [expected] => 4c81a5b47dae993a0280a01c8fec409d716f812e943af52de6a0729509aaf7f9a83b39c449cc0b51fd6d0909550b2cf87e3663d424ae8817d601f6ce8f4e0a8e
                        [current] =>
                [core/doc/admin/maintenance/enable_maintenance.html] => Array
                        [expected] => 0d2d1c45b41ef372a24729918ef1fd8f13a2f0be60c5d8f4598208a69af74ad22d15d86bcd23a5aeaad120b07d75c5e2843b1a211e877e432993b7569802413b
                        [current] =>
                [core/doc/admin/maintenance/index.html] => Array
                        [expected] => 78d3b71ef62b9ec17278eccfe751c3b5fd67788acb44f444ef091578a254f073fad99a4bcb1bdf40cb9a31c637d82ebb83ee86286ae51a86e6c3357b9c7d2eb2
                        [current] =>
                [core/doc/admin/maintenance/manual_upgrade.html] => Array
                        [expected] => a410902c20771bd9db83592c22fd70c9c3cab794417be8f42c7220c3e6c17710ac40b3314213162f83141cfb0019e0b7fec337d37033ccf712cba70f27ba20b3
                        [current] =>
                [core/doc/admin/maintenance/migrating.html] => Array
                        [expected] => 328c795b2d11cc8f472e68046410172b743be2b7f3c65f63679f4f0be6c6dd20c838d8acd7785a9842cbf9609534b26a38257902a599280eec55937cc1a9cfad
                        [current] =>
                [core/doc/admin/maintenance/package_upgrade.html] => Array
                        [expected] => 4ddc3e7d55b8d1f3ae521af3450c70212d21eb9ec9629c14fd6b75fe62747e3ab066d8002fddf10fd83a48bf1d939b639d8a1a3b451a7bd8701be58a89617887
                        [current] =>
                [core/doc/user/_images/kdes7.png] => Array
                        [expected] => 62d960be3f6c578cfbb9f6e0b9471a44504cc9df2af4f604eb19cee0322029c25eaf3d542692470f6b3155af04045f99ca3b85fe40c57b00ebe8565bb8d05393
                        [current] =>
                [core/doc/user/whats_new.html] => Array
                        [expected] => 7c8276a0041c6a613610ce69d75c3d90c07181ac1139ab44dc363fd1576f9259d5bdc0902318b00f6ed7d83060b20f2559187c9196d9e77d2d1da2a04fc0faae
                        [current] =>
        [INVALID_HASH] => Array
                [lib/private/Config.php] => Array
                        [expected] => 9cc2fa7a56b2f1249c87019ad356fb79e2bbeb277c7e9be4e5887503ed8604e84cb2f8d712899db20ba2a5e740605103a7a148560ab1f2f69477355920babe55
                        [current] => 1461ff351a6a3c0323e8b6ddc5ebcc1ec99a4b255a9da603b9b28224baa12b688e057c29089aa63f3986a6ebdc4f51680ca4949831330c7e4fe9feff9657bfdf
</details>
**List of activated apps:**
<details>
<summary>App list</summary>
If you have access to your command line run e.g.:
sudo -u www-data php occ app:list
from within your Nextcloud installation folder
</details>
**The content of config/config.php:**
<details>
<summary>Config report</summary>
“system”: {
“datadirectory”: “/media/owncloud/data”,
“trusted_domains”: [
“localhost”,
“127.0.0.1”,
“cloud.example.de”,
“hub.example.de”,
“apps_paths”: [
“path”: “/usr/share/webapps/nextcloud/apps2”,
“url”: “/apps2”,
“writable”: true
“path”: “/var/lib/nextcloud/apps”,
“url”: “/apps”,
“writable”: false
“memcache.local”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “redis”,
“port”: 6379
“memcache.locking”: “\OC\Memcache\Redis”,
“version”: “9.1.1.5”,
“dbhost”: “db”,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“dbname”: “owncloud”,
“loglevel”: 1,
“logfile”: “/media/owncloud/logs/owncloud/owncloud.log”,
“appstoreenabled”: true,
“appstoreurl”: “https://apps.nextcloud.com”,
“instanceid”: “oclz2jzghg7i”,
“theme”: “”,
“maintenance”: false,
“mail_from_address”: “cloud”,
“mail_smtpmode”: “smtp”,
“mail_domain”: “grundstil.de”,
“mail_smtpauth”: 1,
“mail_smtpauthtype”: “LOGIN”,
“mail_smtphost”: “mail.grundstil.de”,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“appstore.experimental.enabled”: true,
“knowledgebaseenabled”: true,
“enable_avatars”: true,
“trashbin_retention_obligation”: “auto”
**Are you using encryption:**no
Client configuration
Browser:
Chrome latest
Operating system:
MacOS / Window
