Hello!
The current result is this:
MariaDB [INFORMATION_SCHEMA]> SELECT NAME, SPACE, FILE_FORMAT FROM INFORMATION_SCHEMA.INNODB_SYS_TABLES WHERE NAME like "nextcloud%";
| NAME | SPACE | FILE_FORMAT |
| nextcloud/oc_accounts | 199 | Antelope |
| nextcloud/oc_activity | 202 | Antelope |
| nextcloud/oc_activity_mq | 205 | Antelope |
| nextcloud/oc_addressbookchanges | 208 | Antelope |
| nextcloud/oc_addressbooks | 213 | Barracuda |
It was caused by myself following MYSQL instruction straightforward without care about MariaDB version
I run
sudo -u www-data php occ maintenance:repair
BEFORE running
MariaDB> USE INFORMATION_SCHEMA;
MariaDB> SELECT CONCAT("ALTER TABLE `", TABLE_SCHEMA,"`.`", TABLE_NAME, "` ROW_FORMAT=DYNAMIC;") AS MySQLCMD FROM TABLES WHERE TABLE_SCHEMA = "nextcloud";
the wrong repair has stopped with an error exactly on oc_addressbooks
Then I discovered the right process
And restarted the whole migration considering MariaDB procedure.
It is like the occ repair has marked the first tables as converted. There is a way to repeat the conversion over these few tables?
What to do now?
I’m sticking in maintenance mode.
Thanks
Nextcloud version 17
Operating system and version ubuntu 18.04
PHP version 7.3
Mariadb 10.1.43
