Hi together.
I had a NextCloudPi running for a few month. But now it is not working anymore. It says that the MariaDB is not running anymore.
Running nc-info
Gathering information...
NextCloudPi version v1.28.1
NextCloudPi image NextCloudPi_03-28-20
distribution Raspbian GNU/Linux 10 \n \l
automount yes
USB devices sda
datadir /media/WD
data in SD no
data filesystem btrfs
data disk usage 733G/7.3T
rootfs usage 3.9G/15G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check error
HTTPD service up
PHP service up
MariaDB service down
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP ***
gateway 192.168.0.1
interface eth0
certificates ***
NAT loopback no
uptime 2:51
The mysql error log says
2020-08-24 18:40:05 0 [Warning] InnoDB: Retry attempts for reading partial data failed.
2020-08-24 18:40:05 0 [ERROR] InnoDB: Tried to read 16384 bytes at offset 6291456, but was only able to read 0
2020-08-24 18:40:05 0 [ERROR] InnoDB: Operating system error number 5 in a file operation.
2020-08-24 18:40:05 0 [ERROR] InnoDB: Error number 5 means 'Input/output error'
2020-08-24 18:40:05 0 [Note] InnoDB: Some operating system error numbers are described at https://mariadb.com/kb/en/library/operating-system-error-codes/
2020-08-24 18:40:05 0 [ERROR] InnoDB: File (unknown): 'read' returned OS error 205. Cannot continue operation
200824 18:40:05 [ERROR] mysqld got signal 6 ;
This could be because you hit a bug. It is also possible that this binary
or one of the libraries it was linked against is corrupt, improperly built,
or misconfigured. This error can also be caused by malfunctioning hardware.
To report this bug, see https://mariadb.com/kb/en/reporting-bugs
We will try our best to scrape up some info that will hopefully help
diagnose the problem, but since we have already crashed,
something is definitely wrong and this may fail.
Server version: 10.3.22-MariaDB-0+deb10u1
key_buffer_size=134217728
read_buffer_size=131072
max_used_connections=0
max_threads=153
thread_count=0
It is possible that mysqld could use up to
key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 466218 K bytes of memory
Hope that's ok; if not, decrease some variables in the equation.
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 0x0 thread_stack 0x49000
The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains
information that should help you find out what is causing the crash.
Writing a core file...
Working directory at /var/lib/mysql
Resource Limits:
Limit Soft Limit Hard Limit Units
Max cpu time unlimited unlimited seconds
Max file size unlimited unlimited bytes
Max data size unlimited unlimited bytes
Max stack size 8388608 unlimited bytes
Max core file size 0 unlimited bytes
Max resident set unlimited unlimited bytes
Max processes 29184 29184 processes
Max open files 16364 16364 files
Max locked memory 65536 65536 bytes
Max address space unlimited unlimited bytes
Max file locks unlimited unlimited locks
Max pending signals 29184 29184 signals
Max msgqueue size 819200 819200 bytes
Max nice priority 0 0
Max realtime priority 0 0
Max realtime timeout unlimited unlimited us
Core pattern: core
