I installed Nextcloud on my OMV server, using docker and portainer, several times (I tested first, then wanted to change the data folder to locate it on my main hard drive) and tested with DuckDNS/Letsencrypt => No Problem
I wanted now to make my final instance using Traefik and cloudflare but i don’t manage to make it work
No problem with the dockercompose, I manage to display the final config webpage on Cloud.MyWebsite.com but it seeme that i cannot connect the database.
I get this error :
"Error while trying to create admin user: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo failed: No address associated with hostname "
The hostname is “db” and the service is also named db it my docker-compose file.
Can you help me ?
Thank you !
