<--! Paste this in GitHub report -->
<details>
<summary>NextCloudPi diagnostics</summary>
NextCloudPi version v1.41.10
NextCloudPi image NextCloudPi_07-21-19
OS Raspbian GNU/Linux 10. 5.10.63-v7l+ (armv7l)
automount no
USB devices sda sdb
datadir /mnt/hd1/nextcloud/data
data in SD no
data filesystem btrfs
data disk usage 1.1T/1.9T
rootfs usage 29G/29G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check error
HTTPD service up
PHP service up
MariaDB service down
Redis service up
HPB service down
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP REMOVED SENSITIVE VALUE
gateway REMOVED SENSITIVE VALUE
interface eth0
certificates REMOVED SENSITIVE VALUE
NAT loopback no
uptime 29min
[Fri Oct 22 00:00:05.347527 2021] [mpm_event:notice] [pid 1390:tid 3069702720] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1d configured – resuming normal operations
[Fri Oct 22 00:00:05.347562 2021] [core:notice] [pid 1390:tid 3069702720] AH00094: Command line: ‘/usr/sbin/apache2’
[Fri Oct 22 09:04:17.197041 2021] [mpm_event:notice] [pid 1390:tid 3069702720] AH00491: caught SIGTERM, shutting down
[Fri Oct 22 09:05:00.234313 2021] [ssl:warn] [pid 1214:tid 3069719104] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri Oct 22 09:05:00.281590 2021] [ssl:warn] [pid 1406:tid 3069719104] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Fri Oct 22 09:05:00.289516 2021] [mpm_event:notice] [pid 1406:tid 3069719104] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1d configured – resuming normal operations
[Fri Oct 22 09:05:00.289624 2021] [core:notice] [pid 1406:tid 3069719104] AH00094: Command line: ‘/usr/sbin/apache2’
[Fri Oct 22 09:22:04.377406 2021] [log_config:warn] [pid 1412:tid 2675958784] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:08.679801 2021] [proxy_fcgi:error] [pid 1412:tid 2755412992] [client 192.168.178.32:56036] AH01071: Got error ‘PHP message: PHP Warning: Unknown: write failed: No space left on device (28) in Unknown on line 0PHP message: PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/sessions) in Unknown on line 0’
[Fri Oct 22 09:22:08.685747 2021] [log_config:warn] [pid 1412:tid 2667566080] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:08.693196 2021] [log_config:warn] [pid 1412:tid 2667566080] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:08.760810 2021] [log_config:warn] [pid 1412:tid 2667566080] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:08.761126 2021] [log_config:warn] [pid 1412:tid 2667566080] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:08.764305 2021] [log_config:warn] [pid 1412:tid 2667566080] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:08.764907 2021] [log_config:warn] [pid 1412:tid 2667566080] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:09.088430 2021] [log_config:warn] [pid 1412:tid 2659173376] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:09.101033 2021] [log_config:warn] [pid 1412:tid 2650780672] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:09.102849 2021] [log_config:warn] [pid 1412:tid 2650780672] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:09.141665 2021] [log_config:warn] [pid 1412:tid 2642387968] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log
[Fri Oct 22 09:22:09.322052 2021] [log_config:warn] [pid 1412:tid 2633995264] (28)No space left on device: [client 192.168.178.32:56036] AH00646: Error writing to /var/log/apache2/other_vhosts_access.log, referer: https://192.168.178.24
I have the same error, but it was after a power outage and hardware crashed. I still haven’t found a fix for it yet… Looks like corrupt database config tables/files
