Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (eg, Ubuntu 20.04): Linux pi 5.15.74-v7l+ #1595 SMP Wed Oct 26 11:05:08 BST 2022 armv7l (Raspbian Lite, head when I boot Raspbian)
Apache or nginx version (eg, Apache 2.4.25): nginx 1.18.0
PHP version (eg, 7.4): php 7.4.30
When I access the nextcloud website, I see SSL error:
“NET::ERR_CERT_AUTHORITY_INVALID”
I issued letsencrypt certificate with my computer certbot (manual, DNS verification) and properly configured to OMV workbench, Portainer Web, File Browser.
But, even though I have a verified certificate, I can’t configure it to my Nextcloud. It doesn’t provide any ways online.
I’ve googled it and tried various ways such as make certificate file on nextcloud directory and nextcloud.enable-https (command not found error was established).
Any ways to configure letsencrypt certificate?
I have access to ssh of original Raspberry Pi directory and shell via Portainer.
Also, installing nextcloud with snap didn’t work for me and I can’t try this since server is in production.
More Info.
I tied 183.xxx.xxx.xxx addr. (Raspberry Pi Addr.) to xxxx.xxxxx.xyz (domain) via Cloudflare (proxy is not applied)
Is this the first time you’ve seen this error? (Y/N): N (from yesterday night ~)
- Visit IP address or domain
- See NET::ERR_CERT_AUTHORITY_INVALID error
Too large to post: retrieved from [root domain address]/settings/admin/logging
https://scianio.notion.site/Nextcloud-log-c13d332db263406db2bb078751347109
'datadirectory' => '/data',
'instanceid' => 'ocy7c05g5e4r',
'passwordsalt' => '*********',
'secret' => '***************',
0 => 'xxxx.xxxxx.xyz',
'version' => '25.0.2.3',
'overwrite.cli.url' => 'https://xxxx.xxxxx.xyz',
'dbname' => 'nextcloud',
'dbhost' => '172.17.0.3',
'dbuser' => 'oc_admin',
'dbpassword' => '*****************',
'mail_smtpmode' => 'smtp',
'mail_sendmailmode' => 'pipe',
'mail_domain' => 'xxxxx.xyz',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtphost' => '**********',
'mail_smtpport' => '***',
'mail_smtpname' => '***************',
'mail_smtppassword' => '*********',
'mail_from_address' => 'admin',
“ls -a” result
access.log
access.log.1
error.log
error.log.1
error.log.2.gz
error.log.3.gz
openmediavault-webgui_access.log
openmediavault-webgui_access.log.1
openmediavault-webgui_access.log.1.gz-2022092200.backup
openmediavault-webgui_access.log.1.gz-2022111300.backup
openmediavault-webgui_access.log.1.gz-2022122116.backup
openmediavault-webgui_access.log.10.gz
openmediavault-webgui_access.log.11.gz
openmediavault-webgui_access.log.12.gz
openmediavault-webgui_access.log.13.gz
openmediavault-webgui_access.log.14.gz
openmediavault-webgui_access.log.2.gz
openmediavault-webgui_access.log.3.gz
openmediavault-webgui_access.log.4.gz
openmediavault-webgui_access.log.5.gz
openmediavault-webgui_access.log.6.gz
openmediavault-webgui_access.log.7.gz
openmediavault-webgui_access.log.8.gz
openmediavault-webgui_access.log.9.gz
openmediavault-webgui_error.log
openmediavault-webgui_error.log.1
openmediavault-webgui_error.log.10.gz
openmediavault-webgui_error.log.11.gz
openmediavault-webgui_error.log.12.gz
openmediavault-webgui_error.log.13.gz
openmediavault-webgui_error.log.14.gz
openmediavault-webgui_error.log.15.gz
openmediavault-webgui_error.log.2.gz
openmediavault-webgui_error.log.3.gz
openmediavault-webgui_error.log.4.gz
openmediavault-webgui_error.log.5.gz
openmediavault-webgui_error.log.6.gz
openmediavault-webgui_error.log.7.gz
openmediavault-webgui_error.log.8.gz
openmediavault-webgui_error.log.9.gz
: Same as Admin>Logging log
