example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.4
Operating system and version (eg, Ubuntu 20.04): Debian 11.3
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.53
PHP version (eg, 7.4): 7.4.28
After upgrading to 23.0.4 it is stuck in maintenance mode. Config says
Is this the first time you’ve seen this error? (Y)
- upgrade via updater.phar
/var/log/nextcloud.log
[/var/www] # tail /log/nextcloud.log
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"ocs.password_policy.API.validate\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"ocs.password_policy.API.validate\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":107,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/apps/password_policy/lib/Capabilities.php","line":59,"function":"linkToOCSRouteAbsolute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/CapabilitiesManager.php","line":69,"function":"getCapabilities","class":"OCA\\Password_Policy\\Capabilities","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":190,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"activity.Activities.showList\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"activity.Activities.showList\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"audioplayer.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"audioplayer.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"contacts.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"contacts.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"cookbook.main.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"cookbook.main.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"dashboard.dashboard.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"notes.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"notes.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
{"reqId":"YmKLK7b8SBstWd5L16laVgAARAE","level":1,"time":"2022-04-22T11:02:03+00:00","remoteAddr":"80.138.165.35","user":"--","app":"no app in context","method":"GET","url":"/nextcloud/index.php/204","message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.19.1","version":"23.0.3.2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":365,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/CachingRouter.php","line":59,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/lib/private/URLGenerator.php","line":91,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":287,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/var/www/nextcloud/lib/private/NavigationManager.php","line":113,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":194,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/var/www/nextcloud/lib/public/Defaults.php","line":168,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSConfigHelper.php","line":304,"function":"getShortFooter","class":"OCP\\Defaults","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":234,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":297,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":951,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"}}
'instanceid' => 'x',
'passwordsalt' => 'x',
'secret' => 'x/x+x',
0 => 'x.x.net',
1 => 'x.x.net',
2 => 'x-x',
'datadirectory' => '/var/nextcloud_data',
'version' => '23.0.4.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'x',
'dbpassword' => 'x+x',
'redis' =>
'host' => '/run/redis/redis.sock',
'port' => 0,
'timeout' => 0,
'password' => '',
'dbindex' => 0,
'logtimezone' => 'UTC',
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'x',
'mail_domain' => 'x.de',
'mail_smtpauth' => 1,
'mail_smtphost' => 'x.x.x',
'mail_smtpsecure' => 'tls',
'mail_smtpname' => 'x',
'mail_smtppassword' => 'x?/x',
'theme' => '',
'logfile' => '/var/log/nextcloud.log',
'loglevel' => 2,
'log_rotate_size' => 10485760,
'htaccess.RewriteBase' => '/nextcloud',
'overwrite.cli.url' => 'https://x.x.x/nextcloud',
'mail_smtpport' => 'x',
[/var/www] # tail /log/apache2/other_vhosts_access.log
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:05:38 +0200] "GET /nextcloud/index.php/204 HTTP/2.0" 503 11578 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:05:38 +0200] "GET /nextcloud/index.php/204 HTTP/2.0" 503 11576 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:05:40 +0200] "GET /nextcloud/status.php HTTP/2.0" 200 981 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:06:01 +0200] "GET /nextcloud/status.php HTTP/2.0" 200 981 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:06:22 +0200] "GET /nextcloud/status.php HTTP/2.0" 200 981 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:06:37 +0200] "GET /nextcloud/status.php HTTP/1.1" 200 5948 "-" "Mozilla/5.0 (Linux) mirall/3.4.4-20220415.123906.a3ece50dd-1.0~focal1 (Nextcloud, linuxmint-5.4.0-109-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:06:43 +0200] "GET /nextcloud/status.php HTTP/2.0" 200 981 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:07:04 +0200] "GET /nextcloud/status.php HTTP/2.0" 200 981 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:07:25 +0200] "GET /nextcloud/status.php HTTP/2.0" 200 981 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0"
darkwing.dynu.net:443 80.138.165.35 - - [22/Apr/2022:13:07:40 +0200] "GET /nextcloud/status.php HTTP/1.1" 200 5948 "-" "Mozilla/5.0 (Linux) mirall/3.4.4-20220415.123906.a3ece50dd-1.0~focal1 (Nextcloud, linuxmint-5.4.0-109-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)"
PASTE HERE
[/var/www] # tail /log/syslog
Apr 22 12:46:08 MCP-Server systemd[1]: Started The Apache HTTP Server.
Apr 22 12:55:00 MCP-Server systemd[1]: Starting Check pmlogger instances are running...
Apr 22 12:55:00 MCP-Server systemd[1]: pmlogger_check.service: Succeeded.
Apr 22 12:55:00 MCP-Server systemd[1]: Finished Check pmlogger instances are running.
Apr 22 12:58:00 MCP-Server systemd[1]: Starting Check PMIE instances are running...
Apr 22 12:58:00 MCP-Server systemd[1]: pmie_check.service: Succeeded.
Apr 22 12:58:00 MCP-Server systemd[1]: Finished Check PMIE instances are running.
Apr 22 13:00:01 MCP-Server CRON[2180408]: (www-data) CMD (/usr/bin/php -f /var/www/nextcloud/cron.php)
Apr 22 13:05:01 MCP-Server CRON[2180604]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
