Maintenance release RCs ready for testing: 15.0.6 RC1 and 14.09 RC1
Hey,
we just published the RCs for the maintenance releases that are planned for next week Thursday. They are all available on the beta channel of the updater.
The changelog can be found below.
Thanks for all the feedback we received in the last weeks and that went into a number of small fixes for our stable releases.
:rocket:
15.0.6 RC1
14.0.8 RC 1
Beta channel offers 16.0.0 Beta 2.
tob_@nextcloud:~$ occ config:system:set updater.release.channel --value beta
System config value updater.release.channel set to string beta
tob_@nextcloud:~$ occ update:check
Nextcloud 15.0.6 RC 1 is available. Get more information on how to update at https://docs.nextcloud.com/server/15/admin_manual/maintenance/upgrade.html.
1 update available
tob_@nextcloud:~$ updater.phar
Nextcloud Updater - version: v14.0.2RC2-7-g57268cb
Current version is 15.0.5.
Update to Nextcloud 16.0.0 Beta 2 available. (channel: "beta")
Following file will be downloaded automatically:  https://download.nextcloud.com/server/prereleases/nextcloud-16.0.0beta2.zip
Steps that will be executed:
[ ] Check for expected files
[ ] Check for write permissions
[ ] Create backup
[ ] Downloading
[ ] Verify integrity
[ ] Extracting
[ ] Enable maintenance mode
[ ] Replace entry points
[ ] Delete old files
[ ] Move new files in place
[ ] Done
Start update? [y/N] ^C
tob_@nextcloud:~$
$ occ --version
Nextcloud 15.0.5
$ occ update:check
Everything up to date
$ occ config:system:get updater.release.channel
$ occ update:check
Am I overlooking something?
I am having the exact same problem. Could this minor update only available for manual installation ?
