Nextcloud version (eg, 12.0.2): 16.04
Operating system and version (eg, Ubuntu 17.04): Ubuntu 16.0.4
PHP version (eg, 7.1): 7.2.22
I have a backup script that runs everyday at 03.00. It also enables maintenance mode and disables it again afterwards when the backup is done (through the occ command). This is handled with systemd.
Strangely, my instance is in maintanence mode already at about 23ish everyday. I don’t know why and have no clue how to debug this.
I couldn’t find a log output of the occ.
Any hints on where to start?
Not in log
With systemctl list-timers
you can output all active timers and see the timezone for each timer. If your timer shows a wrong timezone there, you could define it in your timer config simply by adding it at the end of the line like:
[Timer]
OnCalendar=*-*-* 03:00:00 CEST
Persistent=true
Indeed, looking good. Also the “15h left” indicates the timer really wants to start at 3 am first.
Might there be another job setting NC in maintenance?
Are there any cronjobs for
www-data
root
any other user you are using to maintain NC
You can check for example with: crontab -l -u www-data
Can you post the complete configuration of your systemd job including the commands for the backup which are executed? Maybe we can put some echo commands in there and output the time to a log file somewhere.
Edit:
One additional question. Did you change the time at some point? Meaning, did you set the backup to be at 23:00 before and changed the time to be 3:00 in the morning later?
Sep 26 03:00:00 this-server systemd[1]: Starting borgmatic backup...
Sep 26 03:00:18 this-server sudo[8556]: root : TTY=unknown ; PWD=/var/www/cloud ; USER=www-data ; COMMAND=/usr/bin/php /var/www/cloud/occ maintenance:mode --on
Sep 26 03:00:18 this-server sudo[8556]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Sep 26 03:00:18 this-server borgmatic[7570]: Maintenance mode already enabled
Sep 26 03:00:18 this-server sudo[8556]: pam_unix(sudo:session): session closed for user www-data
Sep 26 03:29:57 this-server sudo[17397]: root : TTY=unknown ; PWD=/ ; USER=www-data ; COMMAND=/usr/bin/php /var/www/cloud/occ maintenance:mode --off
Sep 26 03:29:57 this-server sudo[17397]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Sep 26 03:29:57 this-server borgmatic[7570]: Maintenance mode disabled
Sep 26 03:29:57 this-server sudo[17397]: pam_unix(sudo:session): session closed for user www-data
Sep 26 03:36:45 this-server systemd[1]: Started borgmatic backup.
Line 4 is as expected (always like this).
I have set this up quite a while ago, so I don’t remember exactly when I run it first. But maybe i tried to run it once on 23.xx, this is possible. But that shouldn’t make any difference, right?
I have also added a line to echo a timestamp, the user that runs it and what the invoking command was to a file everytime it runs (the actual backup).
Okay, so there was quite a misunderstanding on my side. I was thinking that the backup starts at the wrong time and therefore NC is in maintenance earlier than expected.
In that case no, it doesn’t matter if you configured a different time earlier.
So we need to find out which is setting NC in maintenance.
Could you search your journal for “occ maintenance:mode --on”?
If your last reboot was performed some days ago already, use journalctl -xe
and then search for the mentioned string to get an idea what is activating the maintenance mode.
