example
longer
example
here
Nextcloud version (eg, 17.0.9 - 18.0.9):
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04.5
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.29
PHP version (eg, 7.1): 7.2.24
The issue you are facing: I upgraded from 17.0.2 to 17.0.9 in the browser updater without issue. Then, in Settings>Overview, it showed another update, to 18.0.9, so I clicked that. It did the download bit and then returned me to Nextcloud to complete the upgrade and then gave me a warning that the apps would be upgraded and some would be disabled because they were incompatible.
It started upgrading apps and then suddenly switched to maintenance mode. It’s been in that state for twenty minutes or so and I am getting very nervous. Am I right to be?
- I can’t, because it’s frozen.
Unavailable at the moment.
GNU nano 2.9.3 config.php
'instanceid' => '*********',
'passwordsalt' => '*****************',
'secret' => '******************',
0 => '**********',
2 => '*********',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '17.0.9.2',
'overwrite.cli.url' => 'http://192.********/nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Spell ^_ Go To Line
GNU nano 2.9.3 error.log
[Thu Sep 24 06:25:01.639879 2020] [http2:warn] [pid 23835] AH10034: The mpm mod$
[Thu Sep 24 06:25:01.667949 2020] [mpm_prefork:notice] [pid 23835] AH00163: Apa$
[Thu Sep 24 06:25:01.667970 2020] [core:notice] [pid 23835] AH00094: Command li$
[Thu Sep 24 07:20:00.978070 2020] [php7:error] [pid 19068] [client 139.196.229.$
[Thu Sep 24 08:32:42.004319 2020] [authz_core:error] [pid 15001] [client 192.16$
[Thu Sep 24 09:26:43.484053 2020] [php7:error] [pid 20254] [client 176.113.115.$
[Thu Sep 24 09:27:06.945796 2020] [authz_core:error] [pid 20254] [client 192.16$
[Thu Sep 24 10:25:23.963032 2020] [php7:error] [pid 25563] [client 137.117.178.$
[Thu Sep 24 10:29:13.971595 2020] [php7:error] [pid 25377] [client 104.131.13.2$
[Thu Sep 24 10:29:13.972047 2020] [php7:error] [pid 26633] [client 104.131.13.2$
[Thu Sep 24 10:58:40.994771 2020] [php7:error] [pid 25378] [client 104.131.13.2$
[Thu Sep 24 12:12:16.783695 2020] [authz_core:error] [pid 27871] [client 192.16$
[Thu Sep 24 12:26:15.134642 2020] [authz_core:error] [pid 29767] [client 192.16$
[Thu Sep 24 12:54:35.798947 2020] [php7:error] [pid 28899] [client 159.89.2.220$
[Thu Sep 24 13:14:31.578949 2020] [php7:error] [pid 29767] [client 148.72.42.18$
[Thu Sep 24 13:31:30.237518 2020] [authz_core:error] [pid 29571] [client 192.16$
[Thu Sep 24 13:41:23.216808 2020] [mpm_prefork:notice] [pid 23835] AH00169: cau$
[Thu Sep 24 13:41:52.318796 2020] [http2:warn] [pid 1359] AH10034: The mpm modu$
[Thu Sep 24 13:41:52.547237 2020] [mpm_prefork:notice] [pid 1359] AH00163: Apac$
I’m guessing this is what’s needed: it’s the error log from the Apache2 folder in /var/log/
I’m leaving it on and going out for a while, to unwind.
Any help or reassurance much appreciated.
