I have a problem with the nextcloud sync client on macos.
It worked fine, but after I reinstalled my nextcloud server, I needed to remove the old login and add the new one.
Now nextcloud ask me for login every system startup. So it opens my web browser and forces me to push the Login button…
Okay, but I think it is enough to remove the files from the client.
I don’t like to remove my smartphone, my desktop pc and my two laptops to fix one client !?
