Nextcloud version (eg, 20.0.5): 24.0.4.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): nginx 1.18.0
PHP version (eg, 7.4): 7.4.3
The issue you are facing: High IO usage by jbd2 service
Is this the first time you’ve seen this error? (Y/N):y
- Install nexcloud
- update to 24.0.4.1
- get problem with HDD perfomance
nothing
it works
nothing intresting
nothing
![2d8517f2-112d-4bc7-b0cb-be8955747ecc|690x225](upload://85Wr232r5AxUCYxeC9iKtfuCwqA.jpeg)
iotop screenshot
