I am not expert or guru but i upgraded to https and i have been having the worst issues with my hosting. They “said” there was a kernel crash and now my nextclouds won’t do the following:
Upload files - keep getting a server disconnection error
Won’t recognize other Federated Cloud ID’s
Wont sync with cell phones
Got message today: Cannot write into “config” directory!
This can usually be fixed by giving the webserver write access to the config directory. See https://docs.nextcloud.com/server/12/go.php?to=admin-dir_permissions
we didn’t make any backend changes?!
Our specs
Nextcloud version: 12.0.3
Operating system: linux
Apache: 2.4.29
PHP: 5.6.32
Can you reliably replicate it? (If so, please outline steps): unknown hosting company wont share this information with us. they did create a lot of “test files” on our rented space
apps wont work,
cant upload files of any size
as of today 11/04/2017: wont send php emails of any sorts.
cant encrypt because we cant get into the apps
gosh I can show you better than I can tell you.
The output of your Nextcloud log in Admin > Logging: we cant get to these files today. should have accessed them BEFORE hosting company changed things - Again.
(make sure you remove any identifiable information!): we cant get to these files today. should have accessed them BEFORE hosting company changed things - Again.
