LostPassword POST not working
Nextcloud version (eg, 18.0.2): 19.0.4
Operating system and version (eg, Ubuntu 20.04): DOCKER => image: nextcloud:production-apache
Apache or nginx version (eg, Apache 2.4.25): DOCKER => image: traefik
PHP version (eg, 7.1): 7.4.11
Reset password not working. I have a network error message.
When I look at the network log on firefox, I get post error. I see that the post is made via http instead of https.
  1. Ask to reset password
  2. cick on the link received by email
  3. set new password and summit.
No log is shown in traefik and nextcloud
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'trusted_proxies' =>
    0 => 'xxx.xxx.xxx.xxx',
    1 => 'xxxx:xxxx:xxxx:xxxx:xxxx::xxxx',
  'overwritehost' => 'nc.nikolov.fr',
  'overwritewebroot' => '/',
  'overwrite.cli.url' => 'https://nc.nikolov.fr',
  'overwritecondaddr' => '^XXX\\.XXX\\.XXX\\.XXX$',
  'redis' =>
    'host' => 'redis',
    'port' => '6379',
  'mail_smtpmode' => 'smtp',
  'mail_smtpsecure' => 'ssl',
  'mail_smtpauth' => true,
  'mail_smtpname' => 'xxxxxxx@xxxxxxxx.fr',
  'mail_smtppassword' => 'xxxxxxxxxxxxx',
  'mail_smtphost' => 'xxxxxx.xxxxx.fr',
  'mail_smtpport' => '465',
  'mail_from_address' => 'noreply-nc',
  'mail_domain' => 'nc.nikolov.fr',
  'mail_smtpdebug' => true,
  'instanceid' => 'xxxxxxxxxxxxx',
  'passwordsalt' => 'xxxxxxxxxxxxxxxxxx+xxxxxxxxxxxxxxx/xxxxxxxxxxx',
  'secret' => 'xxxxxxxxxxxxxx/xxxxxxxxxxxxxx/xxxxxxxxxxxxxxx',
    0 => 'nc.nikolov.fr',
    1 => 'onlyoffice-documentserver-data',
  'version' => '19.0.4.2',
  'dbname' => 'nextcloud',
  'dbhost' => 'nc_mariadb',
  'dbuser' => 'xxxxxx',
  'dbpassword' => 'xxxxxxxxxx',
  'onlyoffice' =>
    'DocumentServerUrl' => '/xxxxxxx/',
    'DocumentServerInternalUrl' => 'http://xxxxxxxxx/',
    'StorageUrl' => 'https://nc.nikolov.fr/',
  'app_install_overwrite' =>
    0 => 'dicomviewer',
    1 => 'ocr',
    2 => 'radio',
    3 => 'camerarawpreviews',
    4 => 'joplin',
  'theme' => '',
  'loglevel' => 0,
No LOG
The output of docker-compose.yml. It give traefik configuration.
services:
  nc:
    mem_limit: 2G
    container_name: nc
    restart: unless-stopped
    ports:
      - 80
    environment:
      - MYSQL_DB=xxxxx
      - MYSQL_USER=xxxxxxxx
      - MYSQL_PASSWORD=xxxxxxxxx
      - MYSQL_HOST=nc_mariadb
      - NEXTCLOUD_ADMIN_USER=xxxxxxxxxxx
      - NEXTCLOUD_ADMIN_PASSWORD=xxxxxxxxx
      - NEXTCLOUD_TRUSTED_DOMAINS="nc.nikolov.fr"
      - REDIS_HOST=redis
      - REDIS_HOST_PORT=6379
      - SMTP_HOST=xxxxx.xxxxxx.fr
      - SMTP_SECURE=ssl
      - SMTP_PORT=465
      - SMTP_AUTHTYPE=LOGIN
      - SMTP_NAME=xxxxx@xxxxxxxxx.fr
      - SMTP_PASSWORD=xxxxxxxxx
      - MAIL_FROM_ADDRESS=noreply-nc
      - MAIL_DOMAIN=nc.nikolov.fr
    volumes:
      - /media/raid5/apps/nextcloud/custom_apps/:/var/www/html/custom_apps/
      - /media/raid5/apps/nextcloud/config/:/var/www/html/config/
      - /media/raid5/apps/nextcloud/cron:/var/spool/cron/crontabs/www-data
      - /media/raid5/nextcloud/:/var/www/html/data/
      - /media/raid5/apps/nextcloud/log/nextcloud.log:/var/log/nextcloud.log
      - nc-volume:/var/run/clamav
    labels:
      - traefik.enable=true
      - traefik.docker.network=01_front
      - traefik.port=80
      # Entrypoint and TLS
      - traefik.http.routers.nc-http.entrypoints=http
      - traefik.http.routers.nc-http.rule=Host(`nc.nikolov.fr`)
      - traefik.http.routers.nc-https.entrypoints=https
      - traefik.http.routers.nc-https.rule=Host(`nc.nikolov.fr`)
      - traefik.http.routers.nc-https.tls=true
      - traefik.http.routers.nc-https.tls.certresolver=le
      # Service
      - traefik.http.services.nc-https.loadbalancer.server.port=80
      # Middlewares
      - traefik.http.routers.nc-http.middlewares=nc-force-https@docker
      - traefik.http.routers.nc-https.middlewares=nc-https@docker,nc-dav@docker,nc-webdav@docker
      # Middlewares nc force https and adds additional headers
      - traefik.http.middlewares.nc-force-https.redirectscheme.scheme=https
      - traefik.http.middlewares.nc-force-https.redirectscheme.permanent=true
      - traefik.http.middlewares.nc-https.headers.customrequestheaders.Forwarded-Proto=https
      - traefik.http.middlewares.nc-https.headers.customFrameOptionsValue=SAMEORIGIN
      - traefik.http.middlewares.nc-https.headers.framedeny=true
      - traefik.http.middlewares.nc-https.headers.sslredirect=true
      - traefik.http.middlewares.nc-https.headers.stsincludesubdomains=true
      - traefik.http.middlewares.nc-https.headers.stspreload=true
      - traefik.http.middlewares.nc-https.headers.stsseconds=15552000
      # Middleware nc-dav replaces .well-known paths for caldav and carddav with proper nextcloud path
      - traefik.http.middlewares.nc-dav.replacepathregex.regex=^/.well-known/ca(l|rd)dav
      - traefik.http.middlewares.nc-dav.replacepathregex.replacement=/remote.php/dav/
      - traefik.http.middlewares.nc-webdav.replacepathregex.regex=^/.well-known/webdav
      - traefik.http.middlewares.nc-webdav.replacepathregex.replacement=/remote.php/dav/
I forgot to put the résult of a curl from the nextcloud container:
docker exec -it nc bash
root@4439ae6ee132:/var/www/html# curl -v http://nc.nikolov.fr
* Expire in 0 ms for 6 (transfer 0x558335010e80)
* Expire in 1 ms for 1 (transfer 0x558335010e80)
* Expire in 0 ms for 1 (transfer 0x558335010e80)
* Expire in 2 ms for 1 (transfer 0x558335010e80)
*   Trying 2a01:e35:2fb5:c884:8000::1...
* TCP_NODELAY set
* Expire in 149997 ms for 3 (transfer 0x558335010e80)
* Expire in 200 ms for 4 (transfer 0x558335010e80)
* Connected to nc.nikolov.fr (2a01:e35:2fb5:c884:8000::1) port 80 (#0)
> GET / HTTP/1.1
> Host: nc.nikolov.fr
> User-Agent: curl/7.64.0
> Accept: */*
< HTTP/1.1 301 Moved Permanently
< Location: https://nc.nikolov.fr/
< Date: Sat, 24 Oct 2020 11:10:51 GMT
< Content-Length: 17
< Content-Type: text/plain; charset=utf-8
* Connection #0 to host nc.nikolov.fr left intact
Moved Permanently
Thanks for your help
