Nextcloud version: 24.0.2
MariaDB Version: 10.6
Both are running in docker containers.
I encounter some queries that are running for a very long time and I don’t see why the database index obviously is not used. Here is some analytics from my database:
MariaDB [(none)]> show processlist;
| Id | User | Host | db | Command | Time | State | Info | Progress |
| 49580 | nextcloud | 172.18.0.3:37872 | nextcloud | Query | 2951 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 49600 | nextcloud | 172.18.0.3:37914 | nextcloud | Query | 2942 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 49731 | nextcloud | 172.18.0.3:38188 | nextcloud | Query | 2684 | Sending data | SELECT `a`.`name` FROM `oc_filecache` `a` LEFT JOIN `oc_filecache` `b` ON `a`.`name` = `b`.`fileid` | 0.000 |
| 50066 | nextcloud | 172.18.0.3:38896 | nextcloud | Query | 2377 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 50523 | nextcloud | 172.18.0.3:39886 | nextcloud | Query | 1998 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 50542 | nextcloud | 172.18.0.3:39928 | nextcloud | Query | 1980 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 50941 | nextcloud | 172.18.0.3:40772 | nextcloud | Query | 1403 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 51689 | nextcloud | 172.18.0.3:42366 | nextcloud | Query | 877 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 51754 | nextcloud | 172.18.0.3:42502 | nextcloud | Query | 831 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 51768 | nextcloud | 172.18.0.3:42530 | nextcloud | Query | 826 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 51821 | nextcloud | 172.18.0.3:42648 | nextcloud | Query | 769 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 51839 | nextcloud | 172.18.0.3:42688 | nextcloud | Query | 742 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 51857 | nextcloud | 172.18.0.3:42726 | nextcloud | Query | 736 | Creating sort index | SELECT `file`.`fileid`, `storage`, `path`, `path_hash`, `file`.`parent`, `name`, `mimetype`, `mimepa | 0.000 |
| 51925 | nextcloud | 172.18.0.3:42874 | nextcloud | Query | 90 | Sending data | SELECT `size`, `unencrypted_size` FROM `oc_filecache` WHERE `parent` = 5 | 0.000 |
| 52251 | nextcloud | localhost | NULL | Query | 0 | starting | show processlist | 0.000 |
| 52414 | nextcloud | 172.18.0.3:43910 | nextcloud | Query | 0 | Updating status | UPDATE `oc_file_locks` SET `lock` = `lock` - '1' WHERE (`key` IN ('files/bed4df36d30a241181bbe10879d | 0.000 |
| 52417 | nextcloud | 172.18.0.3:43916 | nextcloud | Sleep | 6 | | NULL | 0.000 |
| 52418 | nextcloud | 172.18.0.3:43918 | nextcloud | Query | 0 | starting | COMMIT | 0.000 |
| 52419 | nextcloud | 172.18.0.3:43920 | nextcloud | Query | 0 | Updating status | COMMIT | 0.000 |
| 52420 | nextcloud | 172.18.0.3:43922 | nextcloud | Query | 0 | Updating status | UPDATE `oc_filecache` SET `size` = '100193455646' WHERE (`fileid` = 240405) AND ((`size` <> '1001934 | 0.000 |
| 52423 | nextcloud | 172.18.0.3:43928 | nextcloud | Query | 0 | Sending data | INSERT INTO `oc_mounts` (`storage_id`,`root_id`,`user_id`,`mount_point`,`mount_id`,`mount_provider_c | 0.000 |
Analyzing the queries it boils down to this statement:
select count(*) from oc_filecache where storage = 1 and (path_hash = '1a1bdb0c874d2a0351463d857646b44a' or (
path LIKE 'appdata_ocprs1rb5wmk/collectives/4/%'));
I can ask MariaDB to explain the execution of that query:
MariaDB [nextcloud]> explain select count(*) from oc_filecache where storage = 1 and (path_hash = '1a1bdb0c874d2a0351463d857646b44a' or (`path` LIKE 'appdata_ocprs1rb5wmk/collectives/4/%'));
| id | select_type | table | type | possible_keys | key | key_len | ref | rows | Extra |
| 1 | SIMPLE | oc_filecache | ALL | fs_storage_path_hash,fs_storage_mimetype,fs_storage_mimepart,fs_storage_size,fs_storage_path_prefix | NULL | NULL | NULL | 2220617 | Using where |
The right key fs_storage_path_prefix
is listed. But it seams not to use it.
Anybody any idea on why this happens?
I know that I am running a newer MariaDB than recommended by nextcloud. I don’t know if it would be fixed with 10.5.
Thanks a lot for your advice.
Roman
