Hi
I have just setup a demo of nextcloud on my server for evaluation and seem to be having an issue when logging out, it does not complete but errors when generating the required token
/nextcloud/index.php/logout?requesttoken=qRoVacwQxUTFOi0Fqx5MFFBy2RKV17VltN1vx/amL%2B0%3D%3A8HEtWKFcp3CmbWpX7U8CXgcl9lDvp%2B1UzpEHjoDPbdg%3D
I get “This site cannot be reached” and the usual “took too long to respond” messages.
Any ideas why this process is timing out?
Thanks in advance
Cheers
Marco
i think this one Help testing 12.0.7 RC1 & 13.0.2 RC1 belongs here… (don’t get irritated by the title of the link)
it says:
Hi
Sorry gave limited info;
The install went well, I am using a reverse proxy setup under IIS7 due to using port 443 for another test currently and nextcloud is run from a pre-installed VM all of which resolve externally without a problem. All other links on each page work without error except when logging out…
The use case was fine nothing out of the ordinary.
Is a strange one for sure…, will try out the RC when it’s released to see if this addresses the problem
Thanks
Marco
