After updating to Nextcloud version 25.0.1, users who are member of a group get a blank page after logging in (URL is stuck at path/to/nextcloud/index.php/login). The login for users who are NOT member of any group works fine so I don’t think it’s a general config or DB issue.
Any idea on what could cause this is highly appreciated!
I also have the same problem. Local groups. Nextcloud 24.07. Next I did an update to 25 but didn’t help.
Situation disallows to use group shares.
In logs there is an error
"message":"Tried to log in USER_NAME but could not verify token",
"message":"Nesting level too deep - recursive dependency? at /path/to/instalation/nextcloud/lib/private/Log/ExceptionSerializer.php#215,
#Edit
However I started to looking at not related disabled applications and found something.
Enabling “Contacts” app solved the issue for me. I never use that as it is pointless in my use case and that should not have any influence, but surprisingly it have.
