Running nextcloud on Ubuntu 14.04 and having problems to login via its android app. Can login as admin user but not as ‘ordinary’ user.
Opened an ‘Issue’ and I was told that it is a redirect problem.
issue
How can I solve this? What information do you need?
I also have this issue.
Created myself a testuser with no group association, get unknown error in app.
Add the user to admin, can login in app.
Remove the user from admin, get unknown error in app.
I cannot see any errors in logs so this is strange.
Can you post a list of enabled apps?
