We want to show a collage of images in the background of the login page. But this leads to the fact that the info messages are hardly visible on the colored background.
For error messages, a shaded frame is already displayed.
See screenshot below.
- Is it possible to introduce shaded frames for the info messages?
- Is it possible to adjust the degree of shading (transparency)?
Thanks, Friedbert
Hello @Friedbert
welcome to the Nextcloud community.
You can create your own theme and change settings there.
Or you use app https://apps.nextcloud.com/apps/theming_customcss and just change some of the css to fit your needs.
btw. your design is kind of stressful IMHO.
Cheers
Hello @rakekniven,
thank you, the app “Custom CSS” solves my problem.
Yes, I know the login page is going to be very colorful and confused.
But it is only this page and there my users will find themselves somewhere.
Regards, Friedbert
