pw44
January 2, 2020, 8:17pm
#1
Hi, after installing nextcloud on an ubuntu 18.04 server, i’m facing problems by login.
Using firefox browesr, i can enter login and password and log in. Using chrome, i can enter login and password but no login.
Webserver apache2, php 7.2 and mysql (mariadb).
Any hint?
Thank in advance.
j-ed
January 2, 2020, 8:19pm
#2
I would recommend to use the search function of this forum, which you find in the upper right corner of the screen. It will show you several matches on your request:
https://help.nextcloud.com/search?q=chrome%20login
pw44
February 10, 2020, 6:36pm
#3
Thanks, but no solution yet.
I have the same problem, it works with Firefox, Edge and Opera but not Chrome!
