OK, now the same thing is happening that happened last night. I seemed to have logged in, but there is a message that says - Problem loading page, reloading ā¦
and then a large white dialog screen shows up and says - This content failed to load. - disappears, comes back, disappears ā¦
When I try to update my (admin) personal data (like the email address) Iām asked to authenticate, but authentication fails. Password has to be correct because it canāt be much simpler.
Oh, and I get - āError while loading browser sessions and device tokensā - now when I try to refresh the browser.
Well at some point it gets rather ineffective trying to solve the problem via forum. It would be best if some experienced admin would login your machine and checked.
thereās absolutely no reason being frustrated with nextcloud since it seems to be an inconsitency (somehow) with your own environment so far.
iām sure if youād run NC in a virtual machine on the same host (a real fresh install on a fesh system) you would succeed.
but since this doesnāt seem to be any option we tried our best to help you getting your problems solved. but wellsā¦ i canāt help you further, iām really sorry.
JimmyKater - thanks for your efforts, but yes there is reason for frustration, and yes there is a consistency - the login keeps looping (a problem that others have had, also with previous versions of NC), and no, the permissions /var/lib/php/session are not the problem in my case. I monitored the directory and can see that PHP is writing itās session tokens there when I access the login screen.
Let me take a moment to re-explain my issue, from the beginning -
I had NC version 10.0.x (?) installed on my Ubuntu 16.04.2 Server. The install went fairly well and worked.
I wanted to upgrade that version, but that went faul, so I de-installed NC and dropped the NC database, including the db and user entries in the mysql database.
No, I did not wipe out the entire server platform and re-install. I only de-installed NC as I just mentioned in #2.
I tried a fresh install of NC, which essentially went well until I tried to login. Thatās when I first experienced the login loop.
I started to āgoogleā the issue and found it was happening to others as well, and on other systems (eg CentOS), but at the same time I decided to install NC on my desktop machine, which never had NC installed on it before, and experienced the same login loop. My desktop machine is Ubuntu 16.04.2 as well, Desktop version of course. I use this machine as my web-app development platform as well. This is where Iāve been for over a week now.
Soā¦
Iāve deleted the NC directory. Dropped the NC database and removed the NC related entries in the mysql db and user tables. Restarted the mysql server.
Unzipped the NC 12.0.3.3 into the same location as my previous attempted install. Changed ownership to www-data:www-data on the entire NC directory structure.
Made sure (again) that my PHP had what it needed, and configured my Apache 2.4.18 with an Alias pointing to the NC install path, which is just outside the VHost doc-root. This is fine because otherwise I would not be getting the initial NC (Wizard) screen. Iām leaving the NC data directory at itās default location.
I enter new data in the Wizard form - new Admin user and PW, mysql db admin user and PW, new NC db name and ālocalhostā with port. The Wizard finishes without any apparent glitch.
I get the login screen and enter the new Admin username and PW, and BAM, wouldnāt you know it, it simply returns me to the login prompt.
Iāve cleared my browser cache a couple of times, no help. I thought, maybe itās a problem with the Chromium version I have installed so I tried Firefox, same problem.
Iām wondering if there was a software package upgrade that might be causing the problem, but thereās no real way for me to check that. My PHP is the current 7.0.22 from Ubuntu. I only install the available software packages from Ubuntu, on both server and desktop.
So, I really appreciate all of your efforts, and if you/we can ever find the cause, Iāll be really great-full. I really like Nextcloud, and need a cloud service/solution.
Iāve just seen the guide you used for installation. The permission settings are from the old documentation and not compatible with the updater app.
In general, do a backup of your system before you run an upgrade. In case it doesnāt work, you can revert to the previous version immediately and run further tests on other systems (or check on the bugtracker if this is a known problem).
If you change too many things at the same time, it is very hard to figure out what is wrong even for experienced users. There could be other updates or coincidences which might cause this problem. At some point it is probably easier to start with a fresh system, ideally you know all the steps and start from a known system (fresh ubuntu image, ā¦) so others can reproduce this problem. Virtual Machines can be very nice as you can take snapshots on the way. LXC, XEN, ā¦ (makes it also easier to move an existing installation to a different host).
Sorry to bump such an old thread but being that this is one of the top results when searching for this error, and that I ran into it on the latest version of Nextcloud at the time of writing (13.0.2.1), I thought it might be relevant to those who may be experiencing this in 2018.
My problem turned out to be local DNS.
I was accessing the machine by hostname in my browser which works without issue for a number of other services that I currrently host on my home network. This includes complex things like GitLab behind an NGINX reverse proxy to simple ICMP and SSH. It did not occur to me to try accessing directly by IP, but when I added the IP as a trusted domain and connected that way, everything began working as expected.
Some background on my setup in case others are in a similar situation.
I am running nextcloud from the latest docker image and migrated from an existing install on a different machine. I used more or less the default settings, except I configured an external MariaDB instance for the database. I use dnsmasq for local network hostname resolution.
My new machine has multiple NICs and my plan was to try to use dnsmasq for failover in case one of those was unavailable. I have not yet worked out a solution for this, but I just wanted to make people aware of another possible cause for this issue other than the PHP session directory permissions that most sites seem to suggest, which in my case wasnāt the issue. In fact, that directory didnāt even exist in the docker image I was using.
Just for the record, as part of my troubleshooting, I did create a new docker container with completely default settings minus setting a port so I could actually reach NC from outside the container and I was still getting issues. I think thatās about as default as you can get so I know itās not any custom configuration I may have done to nextcloud. The install wizard would finish and I could even log in, but I got the white screen with āThis content failed to loadā and āError while loading browser sessions and device tokensā when I navigated to the settings.
I know my setup isnāt exactly typical but maybe this will help someone else.
