Nextcloud version (eg, 12.0.2): 16.0.3 (but attempted to load 16.0.0, and 15.0.0 under a different folder, with similar results)
Operating system and version (eg, Ubuntu 17.04): Fedora Core 30
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.39
PHP version (eg, 7.1): 7.3.7
Attempting to login results in being redirected to the login page.
- Browse
- Type in any username/password (doesn’t even have to be a registered user)
- redirected to host/nextcloud/index.php/login?redirect_url=/nextcloud/index.php/apps/files/ via status code 303
Nothing present except failed logins from the nextcloud app, interestingly nothing from my attempts from logins from users that don't even exist.
'instanceid' => 'fake thing',
0 => 'longwing.us',
1 => '192.168.2.3',
'datadirectory' => '/mymedia/CloudStore',
'version' => '16.0.3.0',
'dbhost' => 'localhost',
'dbname' => 'fakedatabase',
'dbuser' => 'fakeusername',
'dbpassword' => 'fakepassword',
'default_language' => 'en',
'force_language' => 'en',
'default_locale' => 'en_US',
'force_locale' => 'en_US',
'defaultapp' => 'files',
'knowledgebaseenabled' => true,
'allow_user_to_change_display_name' => true,
'remember_login_cookie_lifetime' => 1296000,
'session_lifetime' => 86400,
'session_keepalive' => true,
'token_auth_enforced' => false,
'auth.bruteforce.protection.enabled' => true,
'skeletondirectory' => '/path/to/nextcloud/core/skeleton',
'lost_password_link' => 'https://example.org/link/to/password/reset',
'mail_domain' => 'example.com',
'mail_smtpdebug' => false,
'mail_smtpmode' => 'smtp',
'mail_smtphost' => '127.0.0.1',
'mail_smtpport' => 25,
'mail_smtptimeout' => 10,
'mail_smtpsecure' => '',
'mail_smtpauth' => false,
'mail_smtpname' => '',
'mail_smtppassword' => '',
'mail_template_class' => '\\OC\\Mail\\EMailTemplate',
'mail_send_plaintext_only' => false,
'mail_smtpstreamoptions' =>
'overwritehost' => '',
'overwriteprotocol' => '',
'overwritewebroot' => '',
'overwritecondaddr' => '',
'overwrite.cli.url' => '',
'htaccess.IgnoreFrontController' => false,
'proxy' => '',
'proxyuserpwd' => '',
'trashbin_retention_obligation' => 'auto',
'versions_retention_obligation' => 'auto',
'appcodechecker' => true,
'updatechecker' => true,
'updater.server.url' => 'https://updates.nextcloud.com/updater_server/',
'has_internet_connection' => true,
'connectivity_check_domains' =>
0 => 'www.nextcloud.com',
1 => 'www.startpage.com',
2 => 'www.eff.org',
3 => 'www.edri.org',
'check_for_working_wellknown_setup' => true,
'check_for_working_htaccess' => true,
'check_data_directory_permissions' => true,
'config_is_read_only' => false,
'log_type' => 'file',
'logfile' => '/var/log/nextcloud.log',
'logfilemode' => 416,
'loglevel' => 2,
'syslog_tag' => 'Nextcloud',
'log.condition' =>
'shared_secret' => 'fake secret',
'users' =>
0 => 'sample-user',
'apps' =>
0 => 'files',
'logdateformat' => 'F d, Y H:i:s',
'log_query' => false,
'log_rotate_size' => 104857600,
'customclient_desktop' => 'https://nextcloud.com/install/#install-clients',
'customclient_android' => 'https://play.google.com/store/apps/details?id=com.nextcloud.client',
'customclient_ios' => 'https://itunes.apple.com/us/app/nextcloud/id1125420102?mt=8',
'customclient_ios_appid' => '1125420102',
'appstoreenabled' => true,
'apps_paths' =>
0 =>
'path' => '/var/www/html/nextcloud/apps',
'url' => '/apps',
'writable' => true,
'enable_previews' => true,
'preview_max_x' => 4096,
'preview_max_y' => 4096,
'preview_max_filesize_image' => 50,
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'preview_office_cl_parameters' => ' --headless --nologo --nofirststartwizard --invisible --norestore --convert-to png --outdir ',
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\HEIC',
4 => 'OC\\Preview\\BMP',
5 => 'OC\\Preview\\XBitmap',
6 => 'OC\\Preview\\MP3',
7 => 'OC\\Preview\\TXT',
8 => 'OC\\Preview\\MarkDown',
'ldapUserCleanupInterval' => 51,
'sort_groups_by_name' => false,
'comments.managerFactory' => '\\OC\\Comments\\ManagerFactory',
'systemtags.managerFactory' => '\\OC\\SystemTag\\ManagerFactory',
'openssl' =>
'config' => '/absolute/location/of/openssl.cnf',
'debug' => true,
'theme' => '',
174.204.31.16 - - [30/Jul/2019:08:52:28 -0400] "POST /nextcloud/index.php/login?redirect_url=/nextcloud/index.php/apps/files/ HTTP/1.1" 303 -
174.204.31.16 - - [30/Jul/2019:08:52:29 -0400] "GET /nextcloud/index.php/apps/files/ HTTP/1.1" 303 -
174.204.31.16 - - [30/Jul/2019:08:52:29 -0400] "GET /nextcloud/index.php/login?redirect_url=/nextcloud/index.php/apps/files/ HTTP/1.1" 200 14711
174.204.31.16 - - [30/Jul/2019:08:52:31 -0400] "GET /nextcloud/cron.php HTTP/1.1" 200 20
(nothing shows up in error log)
Apologies, I should have posted this along with the original report, however yes I have tried different browsers, different devices, clearing cache, even a fresh install of one of my work stations (converting away from windows at the time so the timing worked out).
I should add here as well that attempts to login through the app has a similar response, returns to login screen.
Password reset, used copy/paste to put the same password in, still failed.
Update: I can access through rclone (using the reset password), however the apps/webpage still fail to login
