- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can.
31.0.2
Debian/OMV
dunno
Nginx Proxy Manager
- PHP version (e.g, 8.3):
dunno
not sure - probably after I add SSL certificate or configure local domain or cloudflare tunnel
docker - portrainer - omv
cloudflare tunnel, tailscale, npm
I have Nextcloud running in Docker on OMV. I have configured a Cloudflare tunnel, Tailscale, and a reverse proxy on NPM. I have several other applications running in Docker, but the issue occurs only with Nextcloud.
When I access it via the local domain (nextcloud.lan.pl) or the public domain through the Cloudflare tunnel (cloud.mypublicdomain.pl), the login page opens without any issues. However, after entering my username and password and clicking “Login,” the login button becomes inactive, and the “Logging in…” message appears with a spinning circle indicating the login process is ongoing – but it stays like that indefinitely, even if I wait for several minutes.
If I refresh the page at this point, the Nextcloud dashboard loads correctly with the user logged in. This happens on both my computer and an Android phone, and for all users (I have multiple accounts created).
However, if I access Nextcloud using its IP address (192.168.1.242), the login process works without any issues.
Additionally, I noticed that when I log in as an administrator and go to “Administration settings,” on the “Overview” tab, where the Security & setup warnings are displayed, the error checking process takes quite a long time. Eventually, a message appears:
“There are some errors regarding your setup.
Error occurred while checking server setup.”
dunno how, but I alredy try to remove docker (also remove manually all files related to) and make fresh docker it is same
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
[PASTE HERE](https://pastebin.com/9qTiqZee)
PASTE
PASTE HERE
The output of occ config:list system
or similar is best, but, if not possible, the contents of your config.php
file from /path/to/nextcloud
is fine (make sure to remove any identifiable information!):
[PASTE HERE](https://pastebin.com/B6z6geDW)
The output of occ app:list
(if possible).
- Use the
preformatted text
formatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
